Tgs Inspired?
CroTrials
I need your opinion on the following..
How much harder is it to ride tgs with a inspired fourplay (90mm stem) then with a stock tgs bike, and why?
And if someone could please explain me this difference in bike geometry.
Also if you could please recommend me the changes in order to make my inspired as much tgs as possible :)
If you want to make your fourplay into a TGS bike, start by buying one of these
A gu le is certainly not a tgs bike.
unfortunately dude you are looking at a frame change really, the inspired is a bit too short and doesnt have the low standover you really need for sidehops dropgaps etc.
I disagree about the standover not being small enough, pop a small seat or mini seat on and I bet you can still tuck like a whopper on sidehops. Also why do you need a tiny frame for drop gaps? You may be different but when I do a drop gap I don't go anywhere near the seat.
Pop a longer stem on the inspired and that will make it more TGS
dropgap part was relating to longer frame rather than standover.
no matter what you do with an inspired really it wont make it a tgs frame thats all im saying, yes a longer stem would make it ride more like one, but it couldnt compete with bikes like pitbulls and gus?
It can't be compared with real tgs bikes no matter what changes i make, I'm aware of that.. I had a 12cm stem a few months ago, but everyone told me to get rid of it.. What size do you recommend? And should i put spacers underneath the stem or not? Thanks allot for the answers ! You've helped allot really!
