Chain Advice
  Ryanonza said:
you need a little slack but chains can be tight then drop too be loose so try a little slack and not too tight you dont your chain snapping !
Ryan.
Not quite sure what you mean, try using punctuation. Did you mean:
You need a little bit of slack in your chain. If the chain is tight it will stretch and become loose so try it with a little bit of slack and keep tightening it. If you try and over tighten it so when it settles it is fine then it will probably snap!
