Pedal Back Brake
subtlecontrast
The Shimano range still have them, Nexus internal 3 speed is the cheapest in the range with standard axle spacing.
This is a roller brake -
This is an internal geared hub with a coaster (back pedal) type brake and 3 internal gears -
You can spot a back pedal hub by the stay on the non-drive side which mounts on the chainstay.
Edited by Pashley26
