Weight Loss
onzatrip
Right...
I've got a pitbull 06 stock, however...i think its a bit porky in its current state, so im thinking about dropping some weight on it.
Spec is as follows:
echo hifi stem
old zoo bars
pro2 on bmf rear
kmc k710
dmr v8s
conti mountian king 2.4 rear
conti mountian king 2.2 front
hope xc on mavic x618 front
hope headset
echo cranks
tensile half bashring
fsa platinum bb
203 bb7
rear 05 magura with echo blade
whats your views/opinions on this? any more suggestions?
I'm contemplating :
* I will be changing frames when i have money for the stinger
* changing the rear wheel if it really is that heavy?
I wouldn't consider myself a basher anymore....but I'm sure someone who i ride with will be able to voice their opinion on this...
Maybe try getting your frame adonized. What tubes are you running? If you are running a front disc then it is lighter to run front rim brake.
what you mean about being adonized ?? im running conti mtb tubes i will be changing to front rim brake
Adonizing is a way of colouring your frame, http://www.trials-forum.co.uk/forum/index....howtopic=140554 example for you there. Most parts are coloured using this. It will save weight because it removes a bit of the material so if you were wanting to save those last few grams as well as making it look pimp then go for that.
Your front wheel is probably letting you down as well. If you are going to go front rim brake get a non disc hub (these can go as little as 60g) and a nice light rim (Y)
EDIT: as said change your pedals too, I recomend the trialtech magnesium ones, they are super good and will save you nearly 200g.(Y)
Edited by Duncy H
