M4RK1992 Posted August 17, 2009 Report Share Posted August 17, 2009 hi there would any snail cams fit this t pro frame? i know the monty ones wont fit but i want to check all the others do. thankshttp://www.supercycles.co.uk/images/onzatprorhs600wide.jpgalso what bolt size does that frame take to fit the snail cams? thanks Quote Link to comment Share on other sites More sharing options...
Muel Posted August 17, 2009 Report Share Posted August 17, 2009 Yeh they've got holes. The Monty ones will fit, just won't be able to reach the bolts because the dropouts are about 6" long. Get some big ones like TrialTechs.Also remember, you need a hub designed for them, otherwise they won't fit in the frame. If you have a T-Pro hub you could always get the hub spacers machined down 3mm either side easily enough and they'll fit no trouble.Or you could just grind them down, but they need to be square with the axis really, otherwise they may put uneven pressure on the cone., which could make it wear unevenly and have tight spots as the axle turns round.So if you know someone with a lathe, it'd be ideal, you could just get them to take 3mm off each spacer. Quote Link to comment Share on other sites More sharing options...
theom Posted August 18, 2009 Report Share Posted August 18, 2009 I know for sure that Neon snailcams fit, tartybikes stock them. Quote Link to comment Share on other sites More sharing options...
callumbreakwell85 Posted August 18, 2009 Report Share Posted August 18, 2009 Yeh they've got holes. The Monty ones will fit, just won't be able to reach the bolts because the dropouts are about 6" long. Get some big ones like TrialTechs.Also remember, you need a hub designed for them, otherwise they won't fit in the frame. If you have a T-Pro hub you could always get the hub spacers machined down 3mm either side easily enough and they'll fit no trouble.Or you could just grind them down, but they need to be square with the axis really, otherwise they may put uneven pressure on the cone., which could make it wear unevenly and have tight spots as the axle turns round.So if you know someone with a lathe, it'd be ideal, you could just get them to take 3mm off each spacer.That post has got me thinking.I have these hubs http://www.trials-uk.co.uk/product.aspx?productid=1229 and a KO KM1 frame. I've just got some snail cams and my wheel won't line up for shit when i tighten it up Quote Link to comment Share on other sites More sharing options...
LukasMcNeal Posted August 18, 2009 Report Share Posted August 18, 2009 If its the bolts the monty ones dont fit but any others will Quote Link to comment Share on other sites More sharing options...
Danny Metcalfe Posted August 19, 2009 Report Share Posted August 19, 2009 V!Z cams work perfectly on mine. Quote Link to comment Share on other sites More sharing options...
Jamie East Posted August 19, 2009 Report Share Posted August 19, 2009 Yeah they'll fit Ive got snail cams on my T-pro, using the original t-pro hub, just have too put the snailcams outside of the frame, doesnt look too gd, but does the job. Quote Link to comment Share on other sites More sharing options...
nickdonboy Posted August 20, 2009 Report Share Posted August 20, 2009 try all smooth ran them on my t-pro. nice and big, piss easy to set up. Quote Link to comment Share on other sites More sharing options...
