Stripped
lewisrzoo
Will i drill it to m6 then put the m5 insert in. Lewis
No, the helicoil kit comes with a special 5.2mm drill bit and a proper tap, you can screw an M5 insert into an M6 thread apparantly, and the pitch seems to not matter, but I wouldn't trust it with the 4 bolt mounts...
Do it properly, it's worth doing.
