Ryanonza Posted August 12, 2009 Report Share Posted August 12, 2009 (edited) Hii all i have an Onza Rip and would like too find out if i would be able to fit a 19'' rim on it ?Thanks Ryan ! Edited August 12, 2009 by Ryanonza Quote Link to comment Share on other sites More sharing options...
PIERPOINT Posted August 12, 2009 Report Share Posted August 12, 2009 Yeh you should aslong as you have the right size spokes ,well thats what i believe, and are rear wheels on trials bike normally 19"? Quote Link to comment Share on other sites More sharing options...
kyeo00 Posted August 12, 2009 Report Share Posted August 12, 2009 I'm not sure because of where the Brakes are- the 19" would obstruct it.I've seen 10+ of these threads asking whether they can fit 19"s on a RIP.And most of them seem to come out with- 'NO'.GL Mat. Quote Link to comment Share on other sites More sharing options...
Ryanonza Posted August 12, 2009 Author Report Share Posted August 12, 2009 Yeah normally do come with 19'' so i just wondered if 19'' would be able too fit on mine dont see how i couldnt thanks anywaysCheers for advice will just have too try it for now and see how it works out !Thanks Quote Link to comment Share on other sites More sharing options...
monkeyseemonkeydo Posted August 12, 2009 Report Share Posted August 12, 2009 It's purely down to the brake setup. Because the Rip comes with a 20" rear rim the brake bosses are welded to be in the correct place for that rim. If you changed to a 19" rim there's a chance you won't be able to set the brake up properly and the pads may not hit the rim properly. It's a gamble basically. Quote Link to comment Share on other sites More sharing options...
Ryanonza Posted August 12, 2009 Author Report Share Posted August 12, 2009 Yeah i see what you mean, best thing for me too do now is try and see if it would work i though that a 19'' would be able too fit with no problems because its quite similar too the Onza Bird !but thanks anyways for the advice Quote Link to comment Share on other sites More sharing options...
Jack Morton Posted August 12, 2009 Report Share Posted August 12, 2009 Why do you want a 19" rim edsactually is it just cause you want a wider rim ? Quote Link to comment Share on other sites More sharing options...
theom Posted August 12, 2009 Report Share Posted August 12, 2009 (edited) Cant see it working, if a 19" would fit surely they would fit one as standard?. 19" rims are alot wider than 20" rims with the tyre on. It might rub on the frame. Edited August 12, 2009 by theom Quote Link to comment Share on other sites More sharing options...
Maladie Posted August 13, 2009 Report Share Posted August 13, 2009 No, just don't bother.It was hard enough getting my v-brake set-up properly on the new Echo rim I got for my Bird, and that already comes with a 19" rear wheel. Unless you bought one of those hubs where you can slide a disc ontowithout having disc mounts on your frame ..But they look shit so Quote Link to comment Share on other sites More sharing options...
alex-trials-boy Posted August 13, 2009 Report Share Posted August 13, 2009 No, just don't bother.It was hard enough getting my v-brake set-up properly on the new Echo rim I got for my Bird, and that already comes with a 19" rear wheel. Unless you bought one of those hubs where you can slide a disc ontowithout having disc mounts on your frame ..But they look shit so i agree with the last bit +1 Quote Link to comment Share on other sites More sharing options...
Ryanonza Posted August 14, 2009 Author Report Share Posted August 14, 2009 sorted out my question now thanks for replys, a 19'' wheel fits perfectly thanksregards Ryan Quote Link to comment Share on other sites More sharing options...
gage-mann Posted August 14, 2009 Report Share Posted August 14, 2009 ino some one that has put a monty 19" back wheel in his brothers onza rip he just needs to get rid of the normal lard pads, tire clearance is fine Quote Link to comment Share on other sites More sharing options...
