Help On Rim
Lei ke si
How to single wall:
Get an angle grinder with a cutting disc and something to hold the rim in. (Vice with soft jaws works well).
Scribe lines connecting the edges of the circles together as far apart as you can, so they look like this:
O
O
The cut along the lines on the waste side, so you're cutting the inner wall out in pieces. Then just use the grinder to go upto the corner box section things.
Leave the corner box sections in though, the rim needs these to have any stregnth at all!
It's surprising how much it saves, I did a 26" Atomz rim, saved 130g.
Edited by Muel
