LiamWood! Posted August 11, 2009 Report Share Posted August 11, 2009 (edited) Right i intended to clean my cylinders inside my caliper so i pumped my lever so they came out but one popped out so i popped it back in by pushing it in with a screwdriver but when i take the screw driver out it just slides back out but not all the way. Ive tryed undoing the adjuster on the lever but nothing works the cylinder just says out.Anybody had this before? or know what to do?Thanks. Edited August 12, 2009 by LiamWood! Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted August 11, 2009 Report Share Posted August 11, 2009 (edited) Ignore me, I'm an idiot. Edited August 11, 2009 by Ben John-Hynes Quote Link to comment Share on other sites More sharing options...
onzatrip Posted August 11, 2009 Report Share Posted August 11, 2009 sorry liam you cant you have to drill to 5.2 to fit the insert! Quote Link to comment Share on other sites More sharing options...
Muel Posted August 11, 2009 Report Share Posted August 11, 2009 You're wrong I'm afraid Ben. M6 threads use a 1mm pitch normally, whereas an M5 uses a 0.8mm pitch.Also a helicoil tap isn't 6mm wide anyway, think mines about 5.7mm. Quote Link to comment Share on other sites More sharing options...
tom@eastcoasttrials Posted August 11, 2009 Report Share Posted August 11, 2009 (edited) hey yeah you can do it the size heilcoil u need is m5x.8 i got mine from a company called uni thread cost like £25 next day Delivery the number is 01803 559595 you get the complet kit , tap, drill bit , 10 x helicoils ,insert tools it a bargin i thought best buy i have had Hope this helped mate Tom@eastcoasttrialsEDIT Only relaised tht you got 6mm threads already bes bet is to get some liquid metal and fill the holes the re-drill and tap and helicoil garrented for life Edited August 11, 2009 by tom@eastcoasttrials Quote Link to comment Share on other sites More sharing options...
Muel Posted August 11, 2009 Report Share Posted August 11, 2009 It's already tapped out to M6 though, what he's asking is if he can fit a helicoil to make it M5.You might be able to get a different kind of insert, I've never looked into it. Quote Link to comment Share on other sites More sharing options...
weirdoku Posted August 11, 2009 Report Share Posted August 11, 2009 I've actaully did this to a mates frame. It was already tapped to M6 but I still put a helicoil in and to this day it still works. Quote Link to comment Share on other sites More sharing options...
Muel Posted August 11, 2009 Report Share Posted August 11, 2009 How did you sort the pitch out? Get an M5x1.0mm bolt?Sounds like it's worth a try, if it doesn't work you'll just have to put up with using M6. Quote Link to comment Share on other sites More sharing options...
tom@eastcoasttrials Posted August 11, 2009 Report Share Posted August 11, 2009 It's already tapped out to M6 though, what he's asking is if he can fit a helicoil to make it M5.You might be able to get a different kind of insert, I've never looked into it. yeah i know mate but i was just giving him some other seggestion if u can get a insert to fit it just liquid metal the holes and re do the complet mounts . Quote Link to comment Share on other sites More sharing options...
weirdoku Posted August 11, 2009 Report Share Posted August 11, 2009 How did you sort the pitch out? Get an M5x1.0mm bolt?Sounds like it's worth a try, if it doesn't work you'll just have to put up with using M6.I didn't, I put a helicoil straight in. Bolt tightens up fine. Quote Link to comment Share on other sites More sharing options...
LiamWood! Posted August 11, 2009 Author Report Share Posted August 11, 2009 Weirdoku you just used a normal helicoil? If so sounds like my clamps will be spared from the drill!Cheers for the quick adive guys! Quote Link to comment Share on other sites More sharing options...
weirdoku Posted August 12, 2009 Report Share Posted August 12, 2009 Weirdoku you just used a normal helicoil? If so sounds like my clamps will be spared from the drill!Cheers for the quick adive guys!Yup, the ones you use in a M5 kit but I used 2.0d. It's longer so more threads. Quote Link to comment Share on other sites More sharing options...
LiamWood! Posted August 12, 2009 Author Report Share Posted August 12, 2009 Sweet cheers pal. Quote Link to comment Share on other sites More sharing options...
Mat Smith!! Posted August 12, 2009 Report Share Posted August 12, 2009 You normally have to use a fancy tap, but it might work without. Quote Link to comment Share on other sites More sharing options...
Muel Posted August 12, 2009 Report Share Posted August 12, 2009 Read the thread Mat you penis... Quote Link to comment Share on other sites More sharing options...
Mat Smith!! Posted August 12, 2009 Report Share Posted August 12, 2009 Read the thread Mat you penis...lol shhh Quote Link to comment Share on other sites More sharing options...
LiamWood! Posted August 12, 2009 Author Report Share Posted August 12, 2009 Help new problem Quote Link to comment Share on other sites More sharing options...
Muel Posted August 12, 2009 Report Share Posted August 12, 2009 You have to push it really hard, and also you might have to disconnect the hose so the air inside has somewhere to go, then re-bleed it. Quote Link to comment Share on other sites More sharing options...
LiamWood! Posted August 12, 2009 Author Report Share Posted August 12, 2009 Ok Muel, could i open the top cap to let the air bubble out? Would it have the same affect becuase the bubbles have further to travel? Quote Link to comment Share on other sites More sharing options...
Muel Posted August 12, 2009 Report Share Posted August 12, 2009 Yeh I think that should work, just watch out for oil spurting out of the resevoir.Also when you've pushed it in, it will compress the air, so you need to hold it in in order to wait for the pressure to drop as it pushes the oil up the hose. Quote Link to comment Share on other sites More sharing options...
LiamWood! Posted August 12, 2009 Author Report Share Posted August 12, 2009 Ok cheers Muel. Quote Link to comment Share on other sites More sharing options...
