alex_trials Posted August 9, 2009 Report Share Posted August 9, 2009 Hey guys,I've overtightened the screw on the ring that attaches the brake to the handlebars by accident and the hole that the bolt screws into has cracked. The crack is about 3-5mm long but it now means that i can't tighten the bolt, so the brake is loose on my handlebars and can swing freely. What can i do about this? (the brake is a Magura HS33.)ThanksAlex Quote Link to comment Share on other sites More sharing options...
Dale-Hill Posted August 9, 2009 Report Share Posted August 9, 2009 Stick a nut on the end of it (need a longer bolt of 'cause)I striped mine the other day too Works better with a nut and bolt IMO too Quote Link to comment Share on other sites More sharing options...
George.E Posted August 9, 2009 Report Share Posted August 9, 2009 This happend to mine but mine came completely off, I just taped to back on for a bit and then sent it to tarty and they rang up an said there sending it to magura incase it was a fault, in which it wasn't , and they got me a completley new leaver and body for free, lol.But iI gess buy a new leaver body. Quote Link to comment Share on other sites More sharing options...
alex_trials Posted August 9, 2009 Author Report Share Posted August 9, 2009 Stick a nut on the end of it (need a longer bolt of 'cause)I striped mine the other day too Works better with a nut and bolt IMO too But surely each time i try to tighten it the same thing will happen: it widens the crack, gets to a certain point and then goes back to the starting point. Quote Link to comment Share on other sites More sharing options...
