LukasMcNeal Posted August 9, 2009 Report Share Posted August 9, 2009 When I go to do a pedal slide into a hop it makes a noise which is best described as a ping. I think its just the noise of the engagement. Then again my chain is quite slack.Anyone else get this? Quote Link to comment Share on other sites More sharing options...
Little Yoshi Posted August 9, 2009 Report Share Posted August 9, 2009 When I go to do a pedal slide into a hop it makes a noise which is best described as a ping. I think its just the noise of the engagement. Then again my chain is quite slack.Anyone else get this?Think its just the chian stating to tenision. Tighting it up and think it should go away. Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted August 9, 2009 Report Share Posted August 9, 2009 Think its just the chian stating to tenision. Tighting it up and think it should go away.yep could be that or loose spokes Quote Link to comment Share on other sites More sharing options...
LukasMcNeal Posted August 9, 2009 Author Report Share Posted August 9, 2009 yep could be that or loose spokes Nah, it's definatley the chain. I've just checked the spokes and were all good. Quote Link to comment Share on other sites More sharing options...
3dd Posted August 9, 2009 Report Share Posted August 9, 2009 Yeah, it is normal, mine does it as well, just a bit of strech I think. Quote Link to comment Share on other sites More sharing options...
LukasMcNeal Posted August 9, 2009 Author Report Share Posted August 9, 2009 Yeah, it is normal, mine does it as well, just a bit of strech I think.Oh that's good then I'll probably just sort the tension out because that's probably why. Quote Link to comment Share on other sites More sharing options...
