chris slater Posted July 30, 2009 Report Share Posted July 30, 2009 Anyone have any idea why echo sl rim brakes always need bleedin?Its water bled and after a few days it starts to feel gash! pulls right the way in!!!!Cheers... Quote Link to comment Share on other sites More sharing options...
ZHI-sam Posted July 30, 2009 Report Share Posted July 30, 2009 leak maybe?? Quote Link to comment Share on other sites More sharing options...
chris slater Posted July 30, 2009 Author Report Share Posted July 30, 2009 leak maybe??No leaks!! its brand new almost! Quote Link to comment Share on other sites More sharing options...
Ciguena_dreamer Posted July 30, 2009 Report Share Posted July 30, 2009 It must be leaking if you have to bleed it all the time..... Quote Link to comment Share on other sites More sharing options...
chris slater Posted July 30, 2009 Author Report Share Posted July 30, 2009 (edited) It must be leaking if you have to bleed it all the time.....Trust me it aint leaking! ???? maybe... cant see any leaks though. Edited July 30, 2009 by chris slater Quote Link to comment Share on other sites More sharing options...
RossMcd Posted July 30, 2009 Report Share Posted July 30, 2009 Bleed it with fluid and it will be fine Water leaks from echo brakes due to the way deng makes them. all the little ridges from CNC'ing lets water out as the water is too thin. However now you have already bled it with water the warranty is now void. Quote Link to comment Share on other sites More sharing options...
LiamWood! Posted July 30, 2009 Report Share Posted July 30, 2009 Well if its needs bleeding all the time air must be getting in somehwhere! Also becuase you have bled it with water you have just lost your warrenty! Quote Link to comment Share on other sites More sharing options...
chris slater Posted July 30, 2009 Author Report Share Posted July 30, 2009 (edited) Well if its needs bleeding all the time air must be getting in somehwhere! Also becuase you have bled it with water you have just lost your warrenty!will have to go see mr poyser for a good fluid bleed!Did do it with maggie bleed kit and used maggie fluid...still gash though! Edited July 30, 2009 by chris slater Quote Link to comment Share on other sites More sharing options...
LiamWood! Posted July 30, 2009 Report Share Posted July 30, 2009 Well if its still gash after a bleed with maggie fluid, its probally you just doing a sham bleed. Quote Link to comment Share on other sites More sharing options...
chris slater Posted July 30, 2009 Author Report Share Posted July 30, 2009 Well if its still gash after a bleed with maggie fluid, its probally you just doing a sham bleed.i know how bleed a brake after over 5 years of ridin! plus i think its the braided crossover..... Quote Link to comment Share on other sites More sharing options...
Rafal Posted July 30, 2009 Report Share Posted July 30, 2009 Trust me it aint leaking! ???? maybe... cant see any leaks though.maybe beacuse the water is transparent and dry quickly...? Quote Link to comment Share on other sites More sharing options...
monkeyseemonkeydo Posted July 30, 2009 Report Share Posted July 30, 2009 However now you have already bled it with water the warranty is now void.Also becuase you have bled it with water you have just lost your warrenty!Really? You could just bleed it through with mineral oil again... I never said that by the way. Quote Link to comment Share on other sites More sharing options...
RossMcd Posted July 30, 2009 Report Share Posted July 30, 2009 Really?You just bleed it through with mineral oil again... I never said that by the way.These brakes come with a 1 year warranty covering manufacturing defects and materials, which also covers the sealing of the brake. Please note that using water to bleed the brake will invalidate the warranty. Quote Link to comment Share on other sites More sharing options...
monkeyseemonkeydo Posted July 30, 2009 Report Share Posted July 30, 2009 Oh yes . Quote Link to comment Share on other sites More sharing options...
Echo-Scott Posted July 30, 2009 Report Share Posted July 30, 2009 Surely you can just run Maggy fluid through the brake a few times and then send it back and claim that its leaking and they wont know the difference? Quote Link to comment Share on other sites More sharing options...
monkeyseemonkeydo Posted July 30, 2009 Report Share Posted July 30, 2009 Surely you can just run Maggy fluid through the brake a few times and then send it back and claim that its leaking and they wont know the difference?. But that would be naughty. Quote Link to comment Share on other sites More sharing options...
Echo-Scott Posted July 30, 2009 Report Share Posted July 30, 2009 . But that would be naughty. Quote Link to comment Share on other sites More sharing options...
..::littlesam::.. Posted July 31, 2009 Report Share Posted July 31, 2009 Trust me it aint leaking! ???? maybe... cant see any leaks though.use logic you tit. it is quite clearly leaking, water cant dissapear inside the hose can it? Quote Link to comment Share on other sites More sharing options...
16 years later Posted July 31, 2009 Report Share Posted July 31, 2009 Surely you can just run Maggy fluid through the brake a few times and then send it back and claim that its leaking and they wont know the difference?No because there is a metal part inside that rusts when you use water. So they can tell Quote Link to comment Share on other sites More sharing options...
liam-pantera Posted August 1, 2009 Report Share Posted August 1, 2009 technically unless you registered the brake when u bought it magura offer no warranty , they used to have a guarantee that if it leaked in 5 years they would replace it for free but you had to register the break when you bought it and also use the receipt and shop name ect i dont know if this is still the case but in all honesty a magura marta doesn't need to be bled with water because its a floating pad design it doesnt need to retract fast and also disk brakes generate alot of heat which will boil the water ... well thats my 2 cents in Quote Link to comment Share on other sites More sharing options...
DannyBazz (: Posted August 1, 2009 Report Share Posted August 1, 2009 (edited) technically unless you registered the brake when u bought it magura offer no warranty , they used to have a guarantee that if it leaked in 5 years they would replace it for free but you had to register the break when you bought it and also use the receipt and shop name ect i dont know if this is still the case but in all honesty a magura marta doesn't need to be bled with water because its a floating pad design it doesnt need to retract fast and also disk brakes generate alot of heat which will boil the water ... well thats my 2 cents in I don't know what topic you're reading.. this is about the echo SL rim brakes not magura martas Edited August 1, 2009 by DannyBazz (: Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted August 1, 2009 Report Share Posted August 1, 2009 No because there is a metal part inside that rusts when you use water. So they can tell They're made out of aluminium though, which doesn't rust. Magura seals are plastic too, which don't corrode, and I'm pretty sure the Echo brakes have the same/similar internals as Maguras anyway... Quote Link to comment Share on other sites More sharing options...
gage-mann Posted August 1, 2009 Report Share Posted August 1, 2009 They're made out of aluminium though, which doesn't rust. Magura seals are plastic too, which don't corrode, and I'm pretty sure the Echo brakes have the same/similar internals as Maguras anyway...steel bleed bolt maybe? Quote Link to comment Share on other sites More sharing options...
