2 Bolt Brake Booster
Warbs
Hi All
Can you fit a two bolt brake booster to a 4 bolt mount set up as I have a couple of 2 bolt boosters.??
They are the magura v brake type boosters.
Tom
Edited by Warbs
Hi All
Tom
Iv got a 2 bolt v booster on my other 20" trials bike it works fine.
Sure you can son.
Just use the normal allen bolts for the top two clamp holes then a longer set for the bottom two with spacers inbetween the clamps and the booster to clear the clamps. (Y)
You just have to tighten the top two bolts before you fit the bottom ones, tricky, but doable.
You might even want to try and modify the booster so it acts like a 4 bolt booster by drilling holes where the top two bolts should go through.
Always ask an adult for help when using sharp tools.
