falmouth_trials Posted July 28, 2009 Report Share Posted July 28, 2009 I am thinking of buying the echo tr slave cylinders, I was wondering what eople thought, any better than the mag ones? All feedback would be appreciated before I spend my heard earned cash! Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted July 28, 2009 Report Share Posted July 28, 2009 I am thinking of buying the echo tr slave cylinders, I was wondering what eople thought, any better than the mag ones? All feedback would be appreciated before I spend my heard earned cash!certainly no better than the magura ones....although if you need extra heel clearance they may be worth considering. The older generation echo slaves have been known to leak apparently, so that's worth bearing in mind. Quote Link to comment Share on other sites More sharing options...
Dale-Hill Posted July 28, 2009 Report Share Posted July 28, 2009 (edited) It's not the cylinders that leak, it's the leaver body But yeah, save your self some cash and get maggy ones.Unless like Alex said, you need more clearance with cranks or whatever.Edit: They leak more with water than oil (obviously..) Edited July 28, 2009 by Dale-Hill Quote Link to comment Share on other sites More sharing options...
falmouth_trials Posted July 28, 2009 Author Report Share Posted July 28, 2009 I do have a problem with clearance on my Czar but presumably that'll mean that there is less adjustment? I was going to bleed with water, and get Goodridge braided houses too, if I did this I presume you shall be able to stop leaking? Oh well shall give it a go, if they're no good then I can always pass them on on here! Incidently I tried using a Monty hose splitter when trying to set up my RB Design lever, anyone had any problems with these also? Quote Link to comment Share on other sites More sharing options...
