How To Keep Grips On
Cotty08
  Adam Griffiths said:
Hairspray your bars then put the grips on.:)
dony use hairspray, use clear lacquer or whatever its called
  Captain Scarlet said:
I've tried loads over the years, with Halfords foams the best thing to do was just slide them on naturally, ensuring that the bar is dry and clean.
Rubber grips the best thing is hairspray or something else that sets tackyish.
And then Trialtech foams moved after the usual slide on technique, so I took them back off and with the advice of the members on here, used spray paint (black obviously is most appropriate).
yeh black spray paint or clear lacquer is the best to use
  • 4 weeks later...
Being a moto-trials rider I had some PJ1 chain lube (the type that turns really sticky) After leaving it for about 15mins to dry my trialtech grips are rock solid where as before they slipped down the bars. Also ensure that your bars and inside of your grips are nice and clean.
