Redneck Posted July 26, 2009 Report Share Posted July 26, 2009 I have one of the pre-2004 levers, the old one with the big red TPA. the bolt that keeps the lever in the master cylinder assembly keeps coming loose after every ride. I almost had the lever fall off during an event. what should i do to keep it nice and tight and make it not back out all the time? Quote Link to comment Share on other sites More sharing options...
Fish-Finger-er Posted July 26, 2009 Report Share Posted July 26, 2009 I have one of the pre-2004 levers, the old one with the big red TPA. the bolt that keeps the lever in the master cylinder assembly keeps coming loose after every ride. I almost had the lever fall off during an event. what should i do to keep it nice and tight and make it not back out all the time?loctite, if you havent got any, toothpaste on the threads will do the trick Quote Link to comment Share on other sites More sharing options...
Sam Nichols Posted July 26, 2009 Report Share Posted July 26, 2009 And if that doesn't work get a long hex bolt and a nylock nut from your local nut and bolt shop. Quote Link to comment Share on other sites More sharing options...
Muel Posted July 26, 2009 Report Share Posted July 26, 2009 (edited) Do you mean the lever blade bolt or the bar clamp bolt?I do this with the lever blade bolts:http://www.trials-forum.co.uk/wiki/How_To_...m_Coming_Undone.I've done method #1 on every maggy I've had for about 2 years, works great.Loctiting doesn't work I've found, it works for a while but always stops working after a few rides. Edited July 26, 2009 by Muel Quote Link to comment Share on other sites More sharing options...
Redneck Posted July 26, 2009 Author Report Share Posted July 26, 2009 thanks, i think im gonna try the longer bolt and the lock nut. Quote Link to comment Share on other sites More sharing options...
Olly Posted July 26, 2009 Report Share Posted July 26, 2009 Mine worked it's way loose a few times every ride.I just put a nut on the end. Haven't touched it since. Quote Link to comment Share on other sites More sharing options...
Mark W Posted July 27, 2009 Report Share Posted July 27, 2009 For some reason, my lever blade bolt used to work it's way tight only when I had a lot of TPA wound on. If you've got your setup like that, maybe give it a bit of a tweak and see if it stops? I've got no idea why it happened, but that stopped it happening for me. Quote Link to comment Share on other sites More sharing options...
Redneck Posted July 27, 2009 Author Report Share Posted July 27, 2009 i dont have too much TPA on, the master cylinder has a bit of a dead spot, the TPA adjuster doesnt touch the plunger untill a bit a TPA has been wound on. ill play with the TPA first and see if that fixes anything. Quote Link to comment Share on other sites More sharing options...
pogo Posted July 27, 2009 Report Share Posted July 27, 2009 And if that doesn't work get a long hex bolt and a nylock nut from your local nut and bolt shop.Works perfectly Quote Link to comment Share on other sites More sharing options...
Mat Smith!! Posted July 28, 2009 Report Share Posted July 28, 2009 Do you mean the lever blade bolt or the bar clamp bolt?I do this with the lever blade bolts:http://www.trials-forum.co.uk/wiki/How_To_...m_Coming_Undone.I've done method #1 on every maggy I've had for about 2 years, works great.Loctiting doesn't work I've found, it works for a while but always stops working after a few rides.Why do you need to file it off? all you need to do is run a longer M5 bolt with a nut on the other side? Quote Link to comment Share on other sites More sharing options...
Revolver Posted July 28, 2009 Report Share Posted July 28, 2009 You file it off if you don't have a longer bolt. Quote Link to comment Share on other sites More sharing options...
Mat Smith!! Posted July 28, 2009 Report Share Posted July 28, 2009 You file it off if you don't have a longer bolt.You can fit a nut on without needing a longer bolt, but its abit dodgy, and its not exactly hard to get a standard magura bolt, so you dont have to void the warrenty Quote Link to comment Share on other sites More sharing options...
Muel Posted July 28, 2009 Report Share Posted July 28, 2009 I filed mine down flat and filed the bolt down too because I didn't want to have it sticking out and looking ugly. Also at the time I couldn't find any recessed M5 bolts long enough. Quote Link to comment Share on other sites More sharing options...
RossMcd Posted July 29, 2009 Report Share Posted July 29, 2009 I had this problem the other day. So I put superglue on the threads and put it back in quickly! Hasnt come slack since Quote Link to comment Share on other sites More sharing options...
Bigman Posted July 29, 2009 Report Share Posted July 29, 2009 I had this problem the other day. So I put superglue on the threads and put it back in quickly! Hasnt come slack since I do a similar method but instead of putting the superglue on the threads i put it on the angled part of the head where it contacts the lever body, always keeps it tight Adam Quote Link to comment Share on other sites More sharing options...
