calumt Posted July 24, 2009 Report Share Posted July 24, 2009 Hey guys, I need some help i wont to change my stem over but my top cap bolt is rounded rather bad so wont loosen. I was just wondering if anyone had any suggestions on how to remove the bolt.Many thanks Calum x Quote Link to comment Share on other sites More sharing options...
Echo-Scott Posted July 24, 2009 Report Share Posted July 24, 2009 Can drill down the top of the bolt. And the head of it will come off . Then lift the top cap off and unscrew the bolt.You will need a new bolt after, But you would need one anyway if its as badly rounded as you have said. Quote Link to comment Share on other sites More sharing options...
Guest itstroy08 Posted July 24, 2009 Report Share Posted July 24, 2009 Just find a .5mm bigger allenkey, and hammer untill it is tight in there. and unscrew, If it gets stuck, wobble side to side, or hammer off.Do not use any grease as it will slip. Quote Link to comment Share on other sites More sharing options...
calumt Posted July 25, 2009 Author Report Share Posted July 25, 2009 Just find a .5mm bigger allenkey, and hammer untill it is tight in there. and unscrew, If it gets stuck, wobble side to side, or hammer off.Do not use any grease as it will slip.I have sorted it, Thanks. Quote Link to comment Share on other sites More sharing options...
