Warbs Posted July 24, 2009 Report Share Posted July 24, 2009 Hello AllI have been looking at the hubs on my bike and wondered if it is possible to changed the sealed berings in the hub??If so have any of you removed them and if so how did you do it??I was then going to try and get some new bearings from the local engineering supplies, as I would guess they would be a standard size, after all Onza Echo etc would not manufacture bearings they would get them supplied by someone like SKF.Thanks in AdvanceTom Quote Link to comment Share on other sites More sharing options...
Robwalker Posted July 24, 2009 Report Share Posted July 24, 2009 What hubs are you running? Most sealed bearings are presses into the hub and need to be punched out one way or another. Quote Link to comment Share on other sites More sharing options...
Warbs Posted July 24, 2009 Author Report Share Posted July 24, 2009 What hubs are you running? Most sealed bearings are presses into the hub and need to be punched out one way or another.They are only Onza hubs.I have a press and have pressed out a few bearings but nothing as light as this. Also there is more than one and it looks like they need to be pulled out from each side. Quote Link to comment Share on other sites More sharing options...
eskimo Posted July 24, 2009 Report Share Posted July 24, 2009 Knock them out using the axle and mallet. It'll still be fine as normal. Just be careful to not kill the whole bearing, don't want the outside of the bearing stuck in the hub and only the centre come flying out. Quote Link to comment Share on other sites More sharing options...
Warbs Posted July 24, 2009 Author Report Share Posted July 24, 2009 Knock them out using the axle and mallet. It'll still be fine as normal. Just be careful to not kill the whole bearing, don't want the outside of the bearing stuck in the hub and only the centre come flying out.I will give that a go thanks again. Quote Link to comment Share on other sites More sharing options...
Guest itstroy08 Posted July 24, 2009 Report Share Posted July 24, 2009 Knock them out using the axle and mallet. It'll still be fine as normal. Just be careful to not kill the whole bearing, don't want the outside of the bearing stuck in the hub and only the centre come flying out.I am using onza t-master hubs, and the center ans bearing came flying out.If this does happen get the smallest chizzle you can find and hammer the chizzle down the outside of the outer ring, then push up and it pops out.I use a 10mm allen key and hammer to get the stuck bearings out. Quote Link to comment Share on other sites More sharing options...
Warbs Posted July 26, 2009 Author Report Share Posted July 26, 2009 I am using onza t-master hubs, and the center ans bearing came flying out.If this does happen get the smallest chizzle you can find and hammer the chizzle down the outside of the outer ring, then push up and it pops out.I use a 10mm allen key and hammer to get the stuck bearings out.Thanks for all your posts I did it this morning all came out fine and all back together!I did not change the bearings as they weren't too bad so I just washed them out in thinners and re greased.Tom Quote Link to comment Share on other sites More sharing options...
