lewiswolsey2009 Posted July 21, 2009 Report Share Posted July 21, 2009 Have read the Wiki section on how to bleed magura's in a bath and have been half successfulThe brake is bled and when the lever is pulled both pistons extend to the rim and do stop meMy only problem is that i have to pull the lever to the handlebars until i get any "bite"Although the bike stops fairly quickly the brake wouldnt hold me if i was to pedal hop.Is there anything i am doing wrong or anything i should be doing, any advice would be appreciated. Quote Link to comment Share on other sites More sharing options...
ghostrider88 Posted July 21, 2009 Report Share Posted July 21, 2009 does it feel spongy?it yes,air is still in the brake so you gotta repeat whole procedure Quote Link to comment Share on other sites More sharing options...
lewiswolsey2009 Posted July 21, 2009 Author Report Share Posted July 21, 2009 does it feel spongy?it yes,air is still in the brake so you gotta repeat whole procedurehmmmm have tried repeating the process about 20 times lol still cant seem to get it !! Quote Link to comment Share on other sites More sharing options...
ghostrider88 Posted July 21, 2009 Report Share Posted July 21, 2009 you should consider another factors:brake set up,pads,rim(grind,dust on it),flexing frame...did you screw tpa all the way out before bleeding? Quote Link to comment Share on other sites More sharing options...
lewiswolsey2009 Posted July 21, 2009 Author Report Share Posted July 21, 2009 you should consider another factors:brake set up,pads,rim(grind,dust on it),flexing frame...did you screw tpa all the way out before bleeding?Im assuming the TPA is the red adjustable nob on the lever, and to be honest i didnt know i had to, and when i have tried it wont physically twist. Quote Link to comment Share on other sites More sharing options...
ghostrider88 Posted July 21, 2009 Report Share Posted July 21, 2009 yep,that´s tpa.try to turn it anti- clockwise direction.if it won´t turn,you´re ok Quote Link to comment Share on other sites More sharing options...
lewiswolsey2009 Posted July 21, 2009 Author Report Share Posted July 21, 2009 yep,that´s tpa.try to turn it anti- clockwise direction.if it won´t turn,you´re okAs far as i can remember it wont turn in any direction lol Quote Link to comment Share on other sites More sharing options...
ghostrider88 Posted July 21, 2009 Report Share Posted July 21, 2009 heh,thats strange,how strong are you? what about that other factors,aren´t the chainstays flexing?check it out,that could decrease brake power very bad Quote Link to comment Share on other sites More sharing options...
lewiswolsey2009 Posted July 21, 2009 Author Report Share Posted July 21, 2009 heh,thats strange,how strong are you? what about that other factors,aren´t the chainstays flexing?check it out,that could decrease brake power very badlmao obviously not strong enough. i have noticed a bit of flex when pulling the brake, but to be honest its only been weak since i rebled it, it was fine before. Quote Link to comment Share on other sites More sharing options...
ghostrider88 Posted July 21, 2009 Report Share Posted July 21, 2009 i think it clear now.just bleed it again,and screw the bleeding bolts onder water if you haven´t before to keep all water in Quote Link to comment Share on other sites More sharing options...
lewiswolsey2009 Posted July 21, 2009 Author Report Share Posted July 21, 2009 i think it clear now.just bleed it again,and screw the bleeding bolts onder water if you haven´t before to keep all water inlol ill give it another go 1 more cant help afterall just everytime i have tried it i have the same result, a brake which will stop me but wont hold. Quote Link to comment Share on other sites More sharing options...
kyeo00 Posted July 21, 2009 Report Share Posted July 21, 2009 heh,thats strange,how strong are you? what about that other factors,aren´t the chainstays flexing?check it out,that could decrease brake power very badLol He's proberbly very strong.Mine broke in like 4 weeks on my Hs33's and it wouldn't turn with any force! Mat. Quote Link to comment Share on other sites More sharing options...
paulboy Posted July 21, 2009 Report Share Posted July 21, 2009 have you tried using the adjustment on the calipers ie u can pull or push the closer/further away from the wheel where they bolt on if there is too much gap then that will explain why your getting this effect. check that all bolts are secure aswell hope this helps Quote Link to comment Share on other sites More sharing options...
kyeo00 Posted July 22, 2009 Report Share Posted July 22, 2009 have you tried using the adjustment on the calipers ie u can pull or push the closer/further away from the wheel where they bolt on if there is too much gap then that will explain why your getting this effect. check that all bolts are secure aswell hope this helpsI'm guessing he has, that's like the simplest thing known to man Mat. Quote Link to comment Share on other sites More sharing options...
lewiswolsey2009 Posted July 22, 2009 Author Report Share Posted July 22, 2009 Lol He's proberbly very strong.Mine broke in like 4 weeks on my Hs33's and it wouldn't turn with any force! Mat.That rather sounds like your hitting on me lmaoI'm guessing he has, that's like the simplest thing known to man Mat.And yeah i have lol Gonna give it all a go today, try a re bleed and then the set up !! Quote Link to comment Share on other sites More sharing options...
kyeo00 Posted July 22, 2009 Report Share Posted July 22, 2009 That rather sounds like your hitting on me lmaoAnd yeah i have lol Gonna give it all a go today, try a re bleed and then the set up !!Haha!Sounds good!Good luck man!Mat. Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted July 22, 2009 Report Share Posted July 22, 2009 how far are the pads away from the rim? are you bleeding with the tpa dialled in? are the pads moving as soon as you pull the lever? Quote Link to comment Share on other sites More sharing options...
lewiswolsey2009 Posted July 22, 2009 Author Report Share Posted July 22, 2009 how far are the pads away from the rim? are you bleeding with the tpa dialled in? are the pads moving as soon as you pull the lever?The TPA isn't moving at all, just wont budgeAnd the pads do move both move equally and easily but when on the bike i have to pull the lever until it's near enough touching the handlebarsAnd the pads are very close to the rim, basically touching. Quote Link to comment Share on other sites More sharing options...
trials-ryan Posted July 22, 2009 Report Share Posted July 22, 2009 (edited) If the t.p.a is not moving its because it's threaded and you should try and bleed the break using a bleeding kit and not a bath its got alot bigger chance of there being no air in the brake when you set it up. Also you might have lazy pistons that will be why they dont move at the same time. Edited July 22, 2009 by trials-ryan Quote Link to comment Share on other sites More sharing options...
