wee neil Posted July 20, 2009 Report Share Posted July 20, 2009 I'm thinking of buying myself a Magura front brake but... I have an Onza Hog rim with drilled sidewalls.Does this work? Do the pads get stuck? Is it worth it? Thanks Neil Quote Link to comment Share on other sites More sharing options...
indianatrials Posted July 20, 2009 Report Share Posted July 20, 2009 Ive never had a onza hog. But im 99.99999999999999999999 percent sure it wouldnt work, even if it did, it wouldnt work good. Quote Link to comment Share on other sites More sharing options...
Sidehop Stuart Posted July 21, 2009 Report Share Posted July 21, 2009 Get a disc brake, and make sure you have disc mounts on forks and a disc hub.Or change rim, and buy the Magura. Quote Link to comment Share on other sites More sharing options...
kyeo00 Posted July 21, 2009 Report Share Posted July 21, 2009 I have the wheel also.to be honest mate, even if it did work the holes would just rip that pads I'm guessing.Not worth taking the risk anyway I suggest a Disc.Mat. Quote Link to comment Share on other sites More sharing options...
wee neil Posted July 21, 2009 Author Report Share Posted July 21, 2009 I already have a Hope Mono Trial but its just not powerful enough and I prefer the feel of the Magura. I think I'll just need to buy a new rim too. Neil Quote Link to comment Share on other sites More sharing options...
zoobert Posted July 21, 2009 Report Share Posted July 21, 2009 (edited) Hi there, I can't honestly say i've ever heard of it being done . The edges of the holes might actually give the pads an edge to bite onto giving it good grip but I think it would be murder on your pads to be honest. I think the best idea would be to stick with a disc rather than shelling out money for a magura , just to find that you would have to buy/build a new wheel.If your Hope brake isn't powerful enough for you as it is you could always try a larger rotor. cheers Edited July 21, 2009 by zoobert Quote Link to comment Share on other sites More sharing options...
kyeo00 Posted July 21, 2009 Report Share Posted July 21, 2009 Hi there, I can't honestly say i've ever heard of it being done . The edges of the holes might actually give the pads an edge to bite onto giving it good grip but I think it would be murder on your pads to be honest. I think the best idea would be to stick with a disc rather than shelling out money for a magura , just to find that you would have to buy/build a new wheel.If your Hope brake isn't powerful enough for you as it is you could always try a larger rotor. cheersDo larget rotors increase the power alot?I can't see how they do.Unless the pads are bigger aswell.More pads touching the metal- more power? Mat. Quote Link to comment Share on other sites More sharing options...
wee neil Posted July 21, 2009 Author Report Share Posted July 21, 2009 I was thinking about trying a bigger rotor too... Do larget rotors increase the power alot?Yeah. It's because with a larger rotor you have more leverage as the calliper is further out on the wheel... Try spinning your wheel and stopping it at the hub (hard isn't it?) then try stopping it with the tyre (easy?). P.S I Suggest you don't try that as you might catch your finger in a spoke and that might hurt Neil. Quote Link to comment Share on other sites More sharing options...
RossMcd Posted July 21, 2009 Report Share Posted July 21, 2009 I have seen this done. And I must say it did work, and it worked well acted almost like grind! Quote Link to comment Share on other sites More sharing options...
kyeo00 Posted July 21, 2009 Report Share Posted July 21, 2009 I was thinking about trying a bigger rotor too... Yeah. It's because with a larger rotor you have more leverage as the calliper is further out on the wheel... Try spinning your wheel and stopping it at the hub (hard isn't it?) then try stopping it with the tyre (easy?). P.S I Suggest you don't try that as you might catch your finger in a spoke and that might hurt Neil.Haha!Good idea!THanks pal Yeah seems to make sense )Mat. Quote Link to comment Share on other sites More sharing options...
ghostrider88 Posted July 22, 2009 Report Share Posted July 22, 2009 it wont work,maggies are too powerful,it will destroy the sidewall in a minute Quote Link to comment Share on other sites More sharing options...
kyeo00 Posted July 22, 2009 Report Share Posted July 22, 2009 it wont work,maggies are too powerful,it will destroy the sidewall in a minuteThought so :/Mat. Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted July 22, 2009 Report Share Posted July 22, 2009 I already have a Hope Mono Trial but its just not powerful enough and I prefer the feel of the Magura. I think I'll just need to buy a new rim too. Neilmon trials are plenty powerful enough...tried a bigger rotor? bad blled? contam'd pads?Hi there, I can't honestly say i've ever heard of it being done . The edges of the holes might actually give the pads an edge to bite onto giving it good grip but I think it would be murder on your pads to be honest. I think the best idea would be to stick with a disc rather than shelling out money for a magura , just to find that you would have to buy/build a new wheel.If your Hope brake isn't powerful enough for you as it is you could always try a larger rotor. cheersit works fine.... joe seddon used one for ages with a grindDo larget rotors increase the power alot?I can't see how they do.Unless the pads are bigger aswell.More pads touching the metal- more power? Mat.yup, more leverage off the hub. KInda controversial that... less pad material would result in more pressure if you think about it, although large3r pads woulkd have a bigger surface for stopping and heat dissipation.it wont work,maggies are too powerful,it will destroy the sidewall in a minuteNope....it works fine, takes a very weak rim to be crushed by a magura. Quote Link to comment Share on other sites More sharing options...
kyeo00 Posted July 22, 2009 Report Share Posted July 22, 2009 mon trials are plenty powerful enough...tried a bigger rotor? bad blled? contam'd pads?it works fine.... joe seddon used one for ages with a grindyup, more leverage off the hub. KInda controversial that... less pad material would result in more pressure if you think about it, although large3r pads woulkd have a bigger surface for stopping and heat dissipation.Nope....it works fine, takes a very weak rim to be crushed by a magura.Thanks for the help pal!Mat. Quote Link to comment Share on other sites More sharing options...
alex-trials-boy Posted July 22, 2009 Report Share Posted July 22, 2009 I have the wheel also.to be honest mate, even if it did work the holes would just rip that pads I'm guessing.Not worth taking the risk anyway I suggest a Disc.Mat.Yea it would hurt the pad if not rip them out you would be going through pads like no tomorrow, try and get a hydrolic disc or a avid bb7 '08 of tarty bikes here the web link:http://www.tartybikes.co.uk/product.php?pr...category_id=514hope ive helped good luck with everything mate. Alex. Quote Link to comment Share on other sites More sharing options...
George.E Posted July 22, 2009 Report Share Posted July 22, 2009 The same topic was on here about a month ago. Quote Link to comment Share on other sites More sharing options...
Jack Morton Posted July 22, 2009 Report Share Posted July 22, 2009 Some one who lives near me did it. Worked brillaintly i thought, Had an amazing bite on it. Pad's lasted about a month or two though. But anyways it work's fine so you can do it. Just use magura black's anyother pad i would say would last a day max. Quote Link to comment Share on other sites More sharing options...
