Echo Tr Rim Brake Anygood?
peggysue
I have been running one now for quite a while, it is very comfortable and as for leaking it is fine so far and I run it with an emulsion fluid, so it has a fair bit of water in. Although I don't get along with the echo cylinders as from experince have found then to be made of cheesey stuff, hard to set up and leak, so I only run mine with magura cylinders. Works a treat!!!
