Eno Problem
rab shropshire
Just wondering if someone can help me out with my eno problems. Here we go lol. When the lockring is off or loose it works fine, but when I tighten the lockring up one of the pawls doesn't engage and it doesnt run smoth and it is very hard to turn. It has recently had new pawls and springs and I have regreased the bearings. also what tool do you need to get it of the crank the tool i have fits other freewheels ie try-all and viz but not the eno. Thanks in advance.
Literally just one of the paws won't engage? Have you got the rubbing o-ring?
no oring i just looked on the eno website and realised i dont have on so that could be the problem but yean only one of the pawls wont engage when its tight. and also 2 of the pawls look different than the others the are longer. it wasnt me that done the work i just thought everything would be fine with it
How do you know just 1 pawl doesnt engage? cause they go in pairs...
I also had an issue with it seeming really stiff after i changed the lock ring.... i just rode it though and its been super duper since, only took one day of riding to be back to normal again and has bee running flawlessly ever since.
Actually, they engage in 3s...
Are the paws level with the engagement teeths?
if you take the seal of you can see the pawls engage and all of them work except 1. Would not having the o-ring make any difference
Ah didn't see this. Forget what I said, you should have 3 short paws and 3 long paws, and they should be placed alternating. So one short then one long and so on. That might be your problem.
when i look on the eno wesite all 3 pawls look the same are the long ones more curved and what pattern should they go in
They are not more curved, they all have the same ends just different in lengths. Take them all out, place them next to each other and see.
Sometimes when its tight to turn but all the bits are put in there properly it's because the plasticy seal on the crank side isn't pushed in properly. It comes out when you take the ratchet off, and you can usually get a screwdriver or your finger to push it back into place.
