8t Multispeed?
sidrug
It would be nice to be able to use a smaller chainwheel on a multispeed bike.
So I just wondered if it would be possible to fit an 8 tooth sprocket next to the 11t sprocket on a multispeed cassette driver. If a bmx 8t driver was threaded on the outside it could replace the cassette lockring?
Or possibly holes could be drilled so it could be bolted onto the lockring?
So the hub would become sometheing like 5-10mm wider, if the cassette driver is not sawed shorter, which may or may not be possible in some hubs..
so maybe it would be possible to bend out the frame by this small amount?
Is there any other way to get an 8t-22t multispeed?
