Problem With Disc Brake!
James 24/7 trials
Hi i used to have this problem on my blade, you need to set your wheel up straight so they should be about 1-3mm space between the rotor itself and the frame and try use the built in snail cams to make the wheel straight, hope i helped.
Rob.
