Ben John-Hynes Posted July 8, 2009 Report Share Posted July 8, 2009 I've realised that my hub could do with a good service, so how do I go about doing it? Bearings, springs, pawls, axle, the lot.Come on TF, help me out. Quote Link to comment Share on other sites More sharing options...
manuel Posted July 8, 2009 Report Share Posted July 8, 2009 so how do I go about doing it?Pull. then hammer axle. done. Quote Link to comment Share on other sites More sharing options...
pogo Posted July 12, 2009 Report Share Posted July 12, 2009 Get a king.Just make sure you know how it all goes back together. Quote Link to comment Share on other sites More sharing options...
Muel Posted July 12, 2009 Report Share Posted July 12, 2009 They's easy Ben, if the drive shell won't just pull out, you can hammer it out with the axle from the disc side.There should be a guide video thing on the hope website for a normal Pro2, you can just use that. PM me if you get stuck if you want pal. Quote Link to comment Share on other sites More sharing options...
Daniel C Posted July 12, 2009 Report Share Posted July 12, 2009 *Thread jack* I also have a question, how do you get the seal back in on the freehub body? Quote Link to comment Share on other sites More sharing options...
Muel Posted July 12, 2009 Report Share Posted July 12, 2009 If you clean up the seal and the inside of the hub, then grease it then it should just press in with no trouble. Quote Link to comment Share on other sites More sharing options...
