Laurence--Trials Posted July 7, 2009 Report Share Posted July 7, 2009 Before I say anything, I would like to apologise for my poor description on this topic.1#Right at the front of the frame where the headset is, my bars/forks are a little wobbly and I cant fix this until Thursday, I was just wondering if this could damage my bike?2#Ok so I can hop backwards about 10 times I find it difficult to hop on the same spot and I really cant hop forward (witch I driving me NUTS!) can anyone describe or give me a link on how I can hop forward? (I’m learning slowly to hop of the same spot, so that’s not really a problem)Thanks.Laurence. Quote Link to comment Share on other sites More sharing options...
Mikey Tomo Posted July 7, 2009 Report Share Posted July 7, 2009 Try putting your pedal forwards slightly more when on the back wheel. And it should be okay until then. Quote Link to comment Share on other sites More sharing options...
Laurence--Trials Posted July 7, 2009 Author Report Share Posted July 7, 2009 oh ok, ill try it cheers. anyone help with first question ? Quote Link to comment Share on other sites More sharing options...
Rob Brodie Posted July 7, 2009 Report Share Posted July 7, 2009 in reply to the first question,all you need to do is loosen the bolts which hold the stem to the forks, then (whilst making sure not to move the bars) tighten the bolt above the bolts you have just loosened.After that tighten all the bolts back up and the 'rocking' should have gone.Just make sure that you havent done the top cap bolt too tight by turning the bars as if you were about to go round a corner, if it feels stiff then do the above steps again but loosen the topcap bolt instead of tightening it slightly.hope this helped..rob.. Quote Link to comment Share on other sites More sharing options...
Maladie Posted July 8, 2009 Report Share Posted July 8, 2009 Laurence--Trials said: Before I say anything, I would like to apologise for my poor description on this topic.1#Right at the front of the frame where the headset is, my bars/forks are a little wobbly and I cant fix this until Thursday, I was just wondering if this could damage my bike?2#Ok so I can hop backwards about 10 times I find it difficult to hop on the same spot and I really cant hop forward (witch I driving me NUTS!) can anyone describe or give me a link on how I can hop forward? (I’m learning slowly to hop of the same spot, so that’s not really a problem)Thanks.Laurence.Hey mate, the pedal kick movement is a pretty hard thing to explain correctly.So have a look at the video's on this website: Http://www.trashzen.comThey should help you out a bit Quote Link to comment Share on other sites More sharing options...
