T Comp
VOLTAGE25
Hi Guys, just went for a new bike and got a split new onza t comp at a great price got pads and chain protection and veggie shin guards thrown in too . Comes with HS33 ft and rear and i was just wondering what boosters to use on the brakes. Can i ask a stupid question ? Whats the difference between 2 and 4 bolt boosters ? Do theY work different ?
Boosters basically stop the frame from flexing when you pull your brake, so putting a brake booster on will make the brake feel rigid and stop the frame from flexing. Technically the 4 bolt boosters will give the frame more support and stop more of the flex than the 2 bolt booster.
Hope i have helped you in some way x
Guest itstroy08
Some 2-bolt boosters are NOT wide enough to fit on a 20", 4-bolt is your safest option.
When you press the lever hard, look at your frame, it will bend outward, a booster eliminates this, so your brake feels amazing.
A very vital part if your frame doesnt have one built in.
