alex copcutt Posted July 6, 2009 Report Share Posted July 6, 2009 Pedal kicks i jus cant seem to get them any ideas?thanks Quote Link to comment Share on other sites More sharing options...
Jack Morton Posted July 6, 2009 Report Share Posted July 6, 2009 Right i learn't by firstly doing in some way's a wheeley. And then started picking my front wheel up and just kicking so i'm doing a wheeley and then pausing in it ( pulling my rear brake on ) i repeated this until i had both the confidence and balance to also hop. And then i soon picked it up. Quote Link to comment Share on other sites More sharing options...
loonytoon Posted July 6, 2009 Report Share Posted July 6, 2009 it took me along time to get the hang of them too, i started by just trying to get my balance on the back wheel an doing small hops with no pedal movement, once you get the hang of this slowly try a little pedal kick in while doing hops on the spot, then progress onto moving forward. its either a case of you will pick it up straight away an off you go or it will take you a long time to get it right with the brake timing just make sure you practice on flat land so not far to fall.hope this is of some help to you, i am kind of rustyben Quote Link to comment Share on other sites More sharing options...
wee neil Posted July 6, 2009 Report Share Posted July 6, 2009 Rember you can always use TrashZen to help learn new moves Quote Link to comment Share on other sites More sharing options...
alex copcutt Posted July 7, 2009 Author Report Share Posted July 7, 2009 thanks guys, really helpful:Dcheers Quote Link to comment Share on other sites More sharing options...
pogo Posted July 7, 2009 Report Share Posted July 7, 2009 Youtube, ryan leech, they are top videos and a great help to noobs. Quote Link to comment Share on other sites More sharing options...
Revolver Posted July 7, 2009 Report Share Posted July 7, 2009 Wheelie-stop is good, and also backhopping.Learning to wheelie-stop teaches you the timing for letting go of your brake, and pedalling. Then, you just add a jump. Quote Link to comment Share on other sites More sharing options...
AaronR504 Posted July 7, 2009 Report Share Posted July 7, 2009 This may sound realy silly but i was trying to learn to pedal kick for absolutely ages and i heard from someone that moving your rear brake lever further down the bar so you can only reach it with one finger helped, i didnt think much of it at the time but after going out one night with some mates and a set of allen keys i decided its worth a shot, and i found it so much easier and after litterally 5mins of preactice like that i couild do them pretty wellhope this helps dude good luck Quote Link to comment Share on other sites More sharing options...
nasheenofteeth Posted July 28, 2009 Report Share Posted July 28, 2009 it took me along time to get the hang of them too, i started by just trying to get my balance on the back wheel an doing small hops with no pedal movement, once you get the hang of this slowly try a little pedal kick in while doing hops on the spot, then progress onto moving forward. its either a case of you will pick it up straight away an off you go or it will take you a long time to get it right with the brake timing just make sure you practice on flat land so not far to fall.hope this is of some help to you, i am kind of rustybenThat sounds like a great idea I think I'll do that for a while, then start to pedal, it's pretty hard to do all those steps all at once. thanks again..This may sound realy silly but i was trying to learn to pedal kick for absolutely ages and i heard from someone that moving your rear brake lever further down the bar so you can only reach it with one finger helped, i didnt think much of it at the time but after going out one night with some mates and a set of allen keys i decided its worth a shot, and i found it so much easier and after litterally 5mins of preactice like that i couild do them pretty wellhope this helps dude good luckI'll have to try this too, thanks Quote Link to comment Share on other sites More sharing options...
Laurence--Trials Posted July 28, 2009 Report Share Posted July 28, 2009 Some people say this is wrong (alexxxx ) 1.Pull a wheelie.2.Do a rear wheel hop.3.Put on rear brake and prepare to land.4.OPTIONAL. Lean back a little to hold the bike up. Hope i helped.Laurence. Quote Link to comment Share on other sites More sharing options...
