Bleeding Magura Help
william
Guest itstroy08
I was using water
And for a challenge tried oil, oil in my opinion sucks,
My pads never return to where they are supposed to be, Its slower, More expensive, Messier, and smells funny
So just a heads up and water bleed all the way. Easy to do aswell. :turned:
You can't bleed Echo brakes with water it will rot the sills.
What echo sill..Which parts is the sill
seals...inside the lever body, the small oring on the piston that seals the system and prevents water leaking..
Although water DOESNT rot the seals, it just to thin for the echo seals to retain fluid
Guest itstroy08
Can i use singer oil to bleed the brake
Just use Magura Royal Blood mate, its costs in the region of £3 off tartybikes, and there is enough to bleed 2 brakes with it.
Guest itstroy08
My side never sell the magura oil..can i use the hope hose to cut and make crossover
Any hose will work, just be sure the connections are in properly
Try De-Ionised water from a car shop, works a treat.
You can use most types of oil. Citreon brake fluid (the old mineral oil one) is the same as magura blood but a different colour, I use cooking oil but this is a bit thick, someone suggested baby oil so I will try this.
And no do not bleed deng brakes with water they will leak, just use oil.
P.S. why can no one in this thread spell correctly or use grammar?
Edited by sstein
  • 5 months later...
