Tightening Wheel Loses Chain Tension?
bikeperson45
I noticed my back wheel was becoming a little loose so quickly tightened it back up, and ever since I've lost the tension. When I pedal backwards the chain goes with it and get dragged to the chainstay protector. When I forst had the hub fitted the guy at the shop said it would take awhile for it to be able to pedal backwards but should it be doing this?
Thanks
Thanks
Move the wheel back then do it up? are you using the cams or tensioners right?
