From Gu Le To Zoo! Pitbull, 26"
Rusty190
  Rafal said:
do you have any problems with this tensioner? skipping? And it has to be that low or can i put it higher? (shorter chain)
Sometimes the chain becomes loose. Im not sure if the tensioner is weak, or my freewheel which is not perfect. When I peddle the chain goes up and down, just a little, and this is probably why the tensioner loose its position. Im not sure, but I don´t think it´s possible with shorter chain :( Notice that im using the older model of the Echo tensioner, I guess the new sprung tensioner is much better!
Edited by Rusty190
