Themistoklidis Posted July 3, 2009 Report Share Posted July 3, 2009 I want to hear your opinions on these two frames. Quote Link to comment Share on other sites More sharing options...
Themistoklidis Posted July 3, 2009 Author Report Share Posted July 3, 2009 Edit:Does any one know if the b3 has a bashplate? Quote Link to comment Share on other sites More sharing options...
Maladie Posted July 3, 2009 Report Share Posted July 3, 2009 I would say go for the B5 mate, looks pretty smart And no, neither of them have bashes. Quote Link to comment Share on other sites More sharing options...
Themistoklidis Posted July 3, 2009 Author Report Share Posted July 3, 2009 (edited) I would say go for the B5 mate, looks pretty smart And no, neither of them have bashes.Thanks do you know if its a big difference between bashplates and bashrings?because i'm used to bashplates...will the frame be messed up,because with my current frame,i use the bashplate quite often ... Edited July 3, 2009 by BikeTrialsInGreece Quote Link to comment Share on other sites More sharing options...
Maladie Posted July 4, 2009 Report Share Posted July 4, 2009 Thanks do you know if its a big difference between bashplates and bashrings?because i'm used to bashplates...will the frame be messed up,because with my current frame,i use the bashplate quite often ...Umm, I don't really but i'd guess having a bash plate would make you wreck your bottom tube alot less.Whereas a bash ring has a much smaller area so gives you less to play with.IMO, just learn to land on your front or back wheel, not in the middle of your frame Quote Link to comment Share on other sites More sharing options...
eskimo Posted July 4, 2009 Report Share Posted July 4, 2009 B3 has no bash plate. B2 does. Geo is pretty normal. Not a bad frame, rides alright. Quote Link to comment Share on other sites More sharing options...
Guest itstroy08 Posted July 7, 2009 Report Share Posted July 7, 2009 What frame do you currently own, and is it a 20" or 26" version you need to know about?If its a 20" you currently own, I might be interested in buying.What frame do you currently own, and is it a 20" or 26" version you need to know about?If its a 20" you currently own, I might be interested in buying. Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted July 7, 2009 Report Share Posted July 7, 2009 I'd say go for the B3 personally, looks nicer Bashring is fine, you just get used to not using the bash protection as something to land on. Plus you'll save a decent bit of weight that way. Quote Link to comment Share on other sites More sharing options...
