Rusty190 Posted July 2, 2009 Report Share Posted July 2, 2009 (edited) I ordered a Zoo! Pitbull 07 frame, short (1060mm) some weeks ago. (My wish is a shorter frame than my GU LE 26" which is 1080mm) I built the Zoo! up today, and after measuring from rear hub to front hub, the distance is 1080mm.The strange thing is that the Zoo! Pitbull 07 only exists in two versions, 1060mm and 1090mm... Or is there a third version out there? Have I received the correct frame? Edited July 2, 2009 by Rusty190 Quote Link to comment Share on other sites More sharing options...
Ciguena_dreamer Posted July 2, 2009 Report Share Posted July 2, 2009 It will be your forks that are making the extra lenght, if you look on tarty's you will see it says measured with Echo etc forks. Your forks might be diffrent geo making the bike longer. Quote Link to comment Share on other sites More sharing options...
Rusty190 Posted July 2, 2009 Author Report Share Posted July 2, 2009 I´ve got Echo Urban forks. Same forks as I had on the GU LE. Quote Link to comment Share on other sites More sharing options...
ogre Posted July 2, 2009 Report Share Posted July 2, 2009 do lots of hooks? it will bend your forks outward. Quote Link to comment Share on other sites More sharing options...
Muel Posted July 2, 2009 Report Share Posted July 2, 2009 Your forks could have bent, but it just sounds to me that you've been sent the long version instead of the short. Quote Link to comment Share on other sites More sharing options...
Rusty190 Posted July 3, 2009 Author Report Share Posted July 3, 2009 Im not doing much hooks. They fork is intact. If the length of 1080mm is correct on the GU LE, it should be correct on the Zoo? Quote Link to comment Share on other sites More sharing options...
pogo Posted July 3, 2009 Report Share Posted July 3, 2009 I bought an 07 control short which was meant to be 1060 but with my forks was only 1045. Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted July 3, 2009 Report Share Posted July 3, 2009 could not be an 07? Quote Link to comment Share on other sites More sharing options...
Rusty190 Posted July 3, 2009 Author Report Share Posted July 3, 2009 Yep it´s the 07 frame. Does anybody know exactly what Echo fork the deng bikes are measured with? Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted July 3, 2009 Report Share Posted July 3, 2009 Are you measuring from/to the centre of each axle? Did you measure the WB of the GU before you de-built it? Or are you just going by what's stated on the internet? Quote Link to comment Share on other sites More sharing options...
Greetings Posted July 3, 2009 Report Share Posted July 3, 2009 If you want to find out if your frame is a short or long, check the bb to headset measurement and confront it with Tarty's website.But yeah, it sounds strange. Quote Link to comment Share on other sites More sharing options...
