Mtchell Posted June 30, 2009 Report Share Posted June 30, 2009 Right so I,ve been told to cut down my steerer...Fair enough I,ve been thinking about doing it for a while now but how much should i be taking off??And secondly what are the benefits?Cheers Quote Link to comment Share on other sites More sharing options...
Mat Smith!! Posted June 30, 2009 Report Share Posted June 30, 2009 Put as many spacers as u want under the stem and then make a mark on the fork at the top of your top cap, then saw off 2-3 mm below that, should be reet. Quote Link to comment Share on other sites More sharing options...
Borat Posted June 30, 2009 Report Share Posted June 30, 2009 (edited) Hack saw and a guide. Cutting down the seerer tube will lower the ride hight by only afew cm's, so you can have such a large amount of stem stackers and it's (only slightly) less liable to snap/crack.You only need to cut off a small amount but be aware you dont cut too much off; towards the star nut.xEDIT: Yeah, what Matt said. Edited June 30, 2009 by Borat Quote Link to comment Share on other sites More sharing options...
Duncy H Posted June 30, 2009 Report Share Posted June 30, 2009 (edited) Well I have just seen the pics of your bike and it looks like it needs cutting, now what you want to do is play around with the stackers to find what height suits you the most, then when you are comfortable just cut them at that length!Edit: too late Edited June 30, 2009 by Duncy H Quote Link to comment Share on other sites More sharing options...
Mtchell Posted June 30, 2009 Author Report Share Posted June 30, 2009 Right cheers guys i,ll go do that now And only benefit being its less likely to snap my steerer it being lower??Hoping one of you would say i could side hop as high as mat if i cut it down lol Quote Link to comment Share on other sites More sharing options...
King C Posted June 30, 2009 Report Share Posted June 30, 2009 Right cheers guys i,ll go do that now And only benefit being its less likely to snap my steerer it being lower??Hoping one of you would say i could side hop as high as mat if i cut it down lol No, not really. The reason people cut down their steer tubes is so that they dont have to run stem stackers on top of the stem, which tends not to be very groin friendly. If you have found a decent stem height that leaves the steerer poking out, then cut the excess off. Quote Link to comment Share on other sites More sharing options...
Mtchell Posted June 30, 2009 Author Report Share Posted June 30, 2009 No, not really. The reason people cut down their steer tubes is so that they dont have to run stem stackers on top of the stem, which tends not to be very groin friendly. If you have found a decent stem height that leaves the steerer poking out, then cut the excess off.oKi DoKi I see why now , well I,ve cut it down by 24mm and it seems right Feels like got more pulling power now lol Quote Link to comment Share on other sites More sharing options...
