Styles Posted June 30, 2009 Report Share Posted June 30, 2009 Hey guys, My friend has bought a 19" rear wheel for his bike, however,the bike has a 20" rear wheel on it at present so the v mounts that are on the bike at the moment I'm guessing won't fit because they will be too high up (?), was wondering if this will be a problem or if it will be alright? also anything else i need to do to the frame to get it to fit?I did this before with maguras but used the EVO mounts and it seemed to be ok, is there anything like this that can help with Vees?cheersalex Quote Link to comment Share on other sites More sharing options...
Maladie Posted June 30, 2009 Report Share Posted June 30, 2009 Styles said: Hey guys, My friend has bought a 19" rear wheel for his bike, however,the bike has a 20" rear wheel on it at present so the v mounts that are on the bike at the moment I'm guessing won't fit because they will be too high up (?), was wondering if this will be a problem or if it will be alright? also anything else i need to do to the frame to get it to fit?I did this before with maguras but used the EVO mounts and it seemed to be ok, is there anything like this that can help with Vees?cheersalexWell most trials bikes I think are made to fit 19 and 20" rear wheels but some will just fit 20's.So maybe have a little read about the bike on tinternet somewhere to find out. Quote Link to comment Share on other sites More sharing options...
Jack Morton Posted June 30, 2009 Report Share Posted June 30, 2009 Not sure on this but if you put the wheel right in would it not fit then. Quote Link to comment Share on other sites More sharing options...
Earl Posted June 30, 2009 Report Share Posted June 30, 2009 trials bikes come in 20" rear or 19" rear brake mounts not both, but if your frame and wheel takes disc then its ok just the tyre may not fit in the frame.Hope that helps. Quote Link to comment Share on other sites More sharing options...
Styles Posted June 30, 2009 Author Report Share Posted June 30, 2009 It is an old 'Da Bomb' frame... Definately not a rear disk going on there In regards to pushing the wheel right in, i think that's what we did last time, as the mounts are for an old 20" rear wheel only, so the brake was biting on the tyre where it sat originally, so we pushed it right in and had to slant the brake, but this was with maguras, so I hope it will do the same with a Vee brake...Cheers for the help guysAlex Quote Link to comment Share on other sites More sharing options...
Guest itstroy08 Posted July 1, 2009 Report Share Posted July 1, 2009 Styles said: It is an old 'Da Bomb' frame... Definately not a rear disk going on there In regards to pushing the wheel right in, i think that's what we did last time, as the mounts are for an old 20" rear wheel only, so the brake was biting on the tyre where it sat originally, so we pushed it right in and had to slant the brake, but this was with maguras, so I hope it will do the same with a Vee brake...Cheers for the help guysAlexJust run a 19" rim with a 20x2.25 to 2.5 size tyre, but with a wilko's innertubeThis will stop the tyre going as bulgy and possibly fit. Quote Link to comment Share on other sites More sharing options...
eskimo Posted July 1, 2009 Report Share Posted July 1, 2009 itstroy08 said: Just run a 19" rim with a 20x2.25 to 2.5 size tyre, but with a wilko's innertubeThis will stop the tyre going as bulgy and possibly fit.That won't fit. If your not good at modification or setup then i wouldn't have bothered. Keep to what's compatible. I'm guessing you've tried the obvious brake setup positions already. Quote Link to comment Share on other sites More sharing options...
Styles Posted July 1, 2009 Author Report Share Posted July 1, 2009 eskimo said: That won't fit. If your not good at modification or setup then i wouldn't have bothered. Keep to what's compatible. I'm guessing you've tried the obvious brake setup positions already.The wheel has not yet arrived, and like i said, i have done this before with maguras... and it is possible, My question if you had read the post was is this a problem with Vee brakes and is there anything that could be done to help... Quote Link to comment Share on other sites More sharing options...
hoptoit Posted July 1, 2009 Report Share Posted July 1, 2009 Styles said: The wheel has not yet arrived, and like i said, i have done this before with maguras... and it is possible, My question if you had read the post was is this a problem with Vee brakes and is there anything that could be done to help... Quote Link to comment Share on other sites More sharing options...
El Cristoff Posted July 1, 2009 Report Share Posted July 1, 2009 If its a 20" frame then 19" wheel won't fit, as the mounts will be an inch out of alignment.Looks like you keep your bike or get a new frame made for 19" rear wheels. Quote Link to comment Share on other sites More sharing options...
