Wide Angle Lens Recommendations Please!
Sam Nichols
37mm is very specific and probably doesn't exist unless part of a zoom lens then passes through 37mm. Also, 37mm isn't wide at all, and its its on a crop sensor DSLR then its most definetly not wide. I'm guessing you're after a prime lens? Also, actually is it for a video camera or a photo camera, film, digital????? Can't really help if you don't say what its for, and lastly for £50 you ain't gunna find screw all!
Yeah I forgot to say it was for a camcorder, and I have seen the ones on ebay but they all looked like unbranded shit to me.
I was thinking along the lines of a few lenses that people use/have used and are good that I can then look on ebay and other sites to try and find a secondhand one in good nick for cheap.
Edited my OP.
Mine was some cheapy jobby that i got off ebay. Came with a macro adapter and i wide angle lens and when using the two together it makes a big difference with how much more you get in the shot but you don't end up with footage that looks like you're carrying an apartment door around strapped to the camera.
Makes life a lot easier with regards to allowing for shooting in tighter spaces.
Pretty sure it was something like this... http://cgi.ebay.co.uk/37-mm-37mm-0-45X-Wid...93%3A1|294%3A50
A lot of people will moan about the glass quality but to be fair unless you're using a HD camera then the lens quality isn't going to be massive due to the lack of image resolution from the camera's sensor anyway.
Had an HD6600 (0.66) and it was a bit narrow. You might want to look at getting something wider.
http://www.vimeo.com/2133753
This is shot with an 0.3 (HD3030 52mm -> 43mm)
Pretty sure this one is shot with the HD6600:
http://www.vimeo.com/1205357
edit: DCR and HD are of different quality, don't know if you'd notice it on a normal DV camera.
Edited by Greetings
I'm struggling to find what I need.
37mm thread
wide enough for filming Jardo's mum but not too 'fishy'
about £50
for a camcorder
can anyone help?
Didnt realise you knew her aswell ;)
Sorry Jardo before you go off on one...
Yes, but also if its a fish eye type lens rather than true wide angle then most of the extra width will be at the edge of frame, as so wit ha big step down you'll end up with less wideangleness*.
*Technical term
