Chain Rubbing Against Snail Cams
omgnoseat
Hey there, I did a search but couldn´t find any similiar topics.
I´m running a mod with snail cams and the chain seems to be rubbing against one, the snail cam has already been filled down, but the chain still rubs.
The rear cog is screwed on the hub as far as possible.
I was thinking of some sort of spacer to increase the distance between the cog and snail cam, but I'm afraid it will mess up the chain line, and put too much "spread" on the chain stays..
Any help?
Thanks in advance
Any help?
Thanks in advance
Just use the smallest spacer you can and fit one either side. I had the same problem with a rockman hub.
Matt
