About Chains In Yaabaa 1499 With Try-all 108.9.
315r
Hello.
My original chain in my yaabaa 1499 is death...
I'm thinking to purchase a best one, at least that this new chain will be more longstanding....
I think that my actual one is KMC try-all : http://www.al4bikes.com/b2c/pop_mas_imagen...1.jpg&act=2
I'm thinking now in KHE Collapse.
What do you think about that?
Other options?
Thank you!!!!
I use a KHE Collapse. And I haven't worried about my chain snapping since I had it. I don't know the strength of that try all chain but it does't look as strong as the collapse.
Thank you!!
and what about weigh? You can feel it more heavy than others?
At least my favourite one nowadays is collapse.
Is compatible My freewhell with collapse?
Edited by 315r
Thank you!!
I don't worry about weight that much, I certainly would not get a light chain that's not as strong over a slightly heavier chain but much smuch stronger.
I'm sure it won't be a problem on any freewheel. I'll be more worried if you have a thin or wide rear sprocket. Since the chain is slightly wider than normal it might rub against your spokes or snail cams (I think your frame uses snail cams..). I use a collapse on a mod and it literally just clears my snail cams by 1mm.
Edited by weirdoku
Yessss. Thank you!!!
I'm seeing my chain now and is very very near of spokes!!! I'm not sure now!! Maybe if this chain "collapse" is bigger touch spokes..
The widest part of this chain is the pins, which are about 10mm wide. If that's wider than the current chain you are running, a collapse might rub against your spokes.
Sadly i'm quite sure that it will happen......
Thank you, maybe i have to think other options.........
If you get this, you should clear the spokes. The teeths are to one side, I'm using a 12T one and it clears my spokes.
UFF! I prefer get a standard chain that start to change other parts of my bike....
Thank you very much, I have been very near of purchase a chain that no works in my bike, Thank you.
Finally i decided to get
a KMC, but a little bit stronger than mine.
Coments??
http://www.al4bikes.com/b2c/pop_mas_imagen...1.jpg&act=1
Specifically which KMC is it? You should be fine with this one, but as with all chains you should chain them in a few months time though, I have seen these snap and I snapped one myself (3/32 size one). I don't think it will rub against your spokes.
Thank you very much Weirdoku for your help, you save me to purchase one thing that doesn't work in my bike. (Y) (Y)
I hope this new one fits well, in the web of the shop the description said: """"Reinforced KMC for freewheel 108,9 Try-all."""""
http://www.al4bikes.com/b2c/index.php?page...ef=tb6301000000
I contacted with shop and said that this one fits well in yaabaas...
Anyway, I will write here my experience with this one in one week.
Thank you again!!!
  • 4 weeks later...
