mr ailsbury Posted June 24, 2009 Report Share Posted June 24, 2009 Right I've somehow snapped the drive shell on my King so obviously I need to replace it, just wondering whether its worth forking out £113.53 for the steel one or is the £55.79 alloy one just as good?cheers Quote Link to comment Share on other sites More sharing options...
aener Posted June 24, 2009 Report Share Posted June 24, 2009 To be honest - this is the first problem I've heard with driveshells - so either everyone's got steel ones, or the ally one is good enough Sorry I can't be more help. Mine's not steel. Quote Link to comment Share on other sites More sharing options...
forteh Posted June 24, 2009 Report Share Posted June 24, 2009 Mines alloy and not really had any problems with it, you need to have really wide based sprockets to stop them digging in though. Kingcogs still dig in alittle but not much.Bear in mind I dont stamp on the pedals and dont put much force through the driveshell Quote Link to comment Share on other sites More sharing options...
aener Posted June 24, 2009 Report Share Posted June 24, 2009 I'm just running a cassette cog It's digging in - but it's taken 3 years of Boumsong stamping down on it the same way... Pretty sure I'll be Ok Quote Link to comment Share on other sites More sharing options...
brick_top Posted June 24, 2009 Report Share Posted June 24, 2009 How wide your sprocket's base is?Standart XC sprockets can dig in steel shell. Quote Link to comment Share on other sites More sharing options...
forteh Posted June 24, 2009 Report Share Posted June 24, 2009 How wide your sprocket's base is?Standart XC sprockets can dig in steel shell.Mine had been run with a standard xc sprocket before I got it, cut almost half way through the splines The king cog digs in about 1/2mm and the trialtech lite is absolutely fine without digging in. Quote Link to comment Share on other sites More sharing options...
jim-p Posted June 24, 2009 Report Share Posted June 24, 2009 Can anyone tell me what the Chris King Standard BMX hubshell and axle are made of?And can you upgrade them?(Sorry for thread-jacking :$ ) Quote Link to comment Share on other sites More sharing options...
forteh Posted June 24, 2009 Report Share Posted June 24, 2009 Can anyone tell me what the Chris King Standard BMX hubshell and axle are made of?And can you upgrade them?(Sorry for thread-jacking :$ )Aluminium in both cases I believe the driveshell is steel on the bmx hub. Quote Link to comment Share on other sites More sharing options...
JonMack Posted June 24, 2009 Report Share Posted June 24, 2009 I was under the impression the axle was steel on the BMX hub, at least thats what ck.com says. Quote Link to comment Share on other sites More sharing options...
forteh Posted June 24, 2009 Report Share Posted June 24, 2009 I was under the impression the axle was steel on the BMX hub, at least thats what ck.com says.Its possible, I thought the HD axles were still aluminium, just alot thicker Quote Link to comment Share on other sites More sharing options...
JonMack Posted June 24, 2009 Report Share Posted June 24, 2009 CK BMX axle is different to HD axles, other than the obvious fact it's shorter, it uses threaded inserts and 3/8" bolts. Quote Link to comment Share on other sites More sharing options...
