Jack Morton Posted June 23, 2009 Report Share Posted June 23, 2009 Quick question would the TNN pad refill's fit in plastic backing's as wanting some but only wanting refill's really.Help would be aprishiatedLink to TNN pad refill's Quote Link to comment Share on other sites More sharing options...
Muel Posted June 23, 2009 Report Share Posted June 23, 2009 I believe they can be trimmed down to fit into standard shaped backings. Quote Link to comment Share on other sites More sharing options...
Jack Morton Posted June 23, 2009 Author Report Share Posted June 23, 2009 I believe they can be trimmed down to fit into standard shaped backings.With a stanley knife ?? Quote Link to comment Share on other sites More sharing options...
Duncy H Posted June 23, 2009 Report Share Posted June 23, 2009 A stanley knife would do the trick, I cut some croco material to put in my phat pad backings and they went in ok, and the phat pad material (with modification to backings) went into the plastic backings quite easily. I would have thought it to be similar for these. Quote Link to comment Share on other sites More sharing options...
Jack Morton Posted June 23, 2009 Author Report Share Posted June 23, 2009 A stanley knife would do the trick, I cut some croco material to put in my phat pad backings and they went in ok, and the phat pad material (with modification to backings) went into the plastic backings quite easily. I would have thought it to be similar for these.I might get some then if they will fit. Quote Link to comment Share on other sites More sharing options...
Le @ Tnn Engineering Posted June 24, 2009 Report Share Posted June 24, 2009 You can get them to fit by hacking them up with a stanley knife. But it won't be easy to get a proper fit due to the tiny square holes.http://www.trialspads.com/shop/trials-brak...sc/refill-pads/So you brake pad is going to end up flexy,under powered and won't hold anywhere as well as it could. If you can I highly recommend the complete LGM pad. I only received excellent feed back about the performance of this compound. Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted June 24, 2009 Report Share Posted June 24, 2009 But it won't be easy to get a proper fit due to the tiny square holes.I used to drill the square corner features out of plastic backings, that means you don't need to modify the pad material But, as Le said, the complete pad is well worth having. Quote Link to comment Share on other sites More sharing options...
