trials biker Posted June 23, 2009 Report Share Posted June 23, 2009 Hi, My ECHO TR rear brake keeps slipping, i have a medium grind recently done and koxx browns, to start with it was fine, about 1.5 hours into riding it started slipping and i don't understand why? i have made sure the brake is set right, any help pleaseP.S. I hate face planting of a rail because of it it hurts ALOT. lol Quote Link to comment Share on other sites More sharing options...
indianatrials Posted June 23, 2009 Report Share Posted June 23, 2009 Most likely your grind got deadened out a little bit. And with those hard pads, the grind needs to be oooober sharp. Quote Link to comment Share on other sites More sharing options...
bigamac Posted June 23, 2009 Report Share Posted June 23, 2009 Try re-bleeding? Quote Link to comment Share on other sites More sharing options...
pogo Posted June 23, 2009 Report Share Posted June 23, 2009 Loss of pressure somewhere? Quote Link to comment Share on other sites More sharing options...
Borat Posted June 23, 2009 Report Share Posted June 23, 2009 Yeah, I would give it a sharp,deep drind. Rebleed and also take your pads off and if they have dust (grey'y) smooth finish one them, sand it off. Quote Link to comment Share on other sites More sharing options...
Paperclip Posted June 23, 2009 Report Share Posted June 23, 2009 yeah, as stated above try a fresh grind or could try new pads? . also a re bleed would atleast even if its not that make you feel better about it. allways keep a close eye on piston's and seals!!!! when using echo brakes as they not allways but mostly after a wee while leak, this can also be avoided on the re bleed but taking all pipe work off the pistons and lever body and using a pump/compressor to get all loose shaving's ect as they do tend to get left in there even though deng try not too. The above is just advice from me as I had echo brakes and both front and back let me down due to this, The back let me down on a gap aswell allways tell that to people when echo brakes are in a conversation just because if you can reduce the chance you might aswell . but the tr should be a very good brake even with a shit bleed, far as i know there pretty much the old rb design and they were sexual brakes! Quote Link to comment Share on other sites More sharing options...
Redneck Posted June 24, 2009 Report Share Posted June 24, 2009 You can try taring your rims. I have a very light grind on my rims then I tar them, uber power. Quote Link to comment Share on other sites More sharing options...
Borat Posted June 24, 2009 Report Share Posted June 24, 2009 You can try taring your rims. I have a very light grind on my rims then I tar them, uber power. So did I, just wait till it rains... Quote Link to comment Share on other sites More sharing options...
trials biker Posted June 25, 2009 Author Report Share Posted June 25, 2009 O thanks guys will try that, the grind isn't that old and the brake is about 3weeks old but i will try it and see what happends. Thanks Quote Link to comment Share on other sites More sharing options...
Sidehop Stuart Posted June 25, 2009 Report Share Posted June 25, 2009 Brake booster? Quote Link to comment Share on other sites More sharing options...
Paperclip Posted June 25, 2009 Report Share Posted June 25, 2009 Brake booster?suck arse! Quote Link to comment Share on other sites More sharing options...
trials biker Posted June 25, 2009 Author Report Share Posted June 25, 2009 Thats very true my frame has the booster built in its an 09 pitbull. Quote Link to comment Share on other sites More sharing options...
Borat Posted June 25, 2009 Report Share Posted June 25, 2009 suck arse!No they dont. Quote Link to comment Share on other sites More sharing options...
pogo Posted June 25, 2009 Report Share Posted June 25, 2009 No they dont.+1 Quote Link to comment Share on other sites More sharing options...
willis-gu Posted June 26, 2009 Report Share Posted June 26, 2009 suck arse!+1 Quote Link to comment Share on other sites More sharing options...
