rob.c Posted June 22, 2009 Report Share Posted June 22, 2009 I have a onza a t-pro with a magura on the back and a tensile 4 bolt booster but when i put it on the brakes was sharp but did not stop me on a rail but with out the booster it was mint. Am i setting it up wrong thanks rob.c Quote Link to comment Share on other sites More sharing options...
rab shropshire Posted June 22, 2009 Report Share Posted June 22, 2009 It could be that when you put the booster on your callipers may have moved out of allignment, due to undoing the bolts. Try setting up your brakes again and go from there. Hope this helps. Quote Link to comment Share on other sites More sharing options...
pogo Posted June 22, 2009 Report Share Posted June 22, 2009 It might be that the increase in stiffness is having a negative on brake power. Do you need the booster? If not sell it for some extra cash = awesome brake and money for shiney parts. Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted June 22, 2009 Report Share Posted June 22, 2009 Yeah, boosters sometimes make your brake worse. WhenI had mine on the brake was good, when I took it off it was unreal. Quote Link to comment Share on other sites More sharing options...
Themistoklidis Posted June 23, 2009 Report Share Posted June 23, 2009 does anyone know a trials website that sells v-brake boosters?i want to buy some for my onza bird and the echo's on Tartybikes are larger and they dont fit..... Quote Link to comment Share on other sites More sharing options...
