simlesuperlol Posted June 18, 2009 Report Share Posted June 18, 2009 (edited) Hi guys i'm getting a Onza pro 2009(t-pro was the old model and I can't find one anymore)cause everybody seems to like it. I just want to know if it's a good thing the 2 disc brakes and want to know the weight if anybody knows it. And does anybody know if the t-pro and the pro are the SAME thing? Edited June 18, 2009 by simlesuperlol Quote Link to comment Share on other sites More sharing options...
adam 94 Posted June 18, 2009 Report Share Posted June 18, 2009 The pro is better as its lighter. Think it weighs around 10kg, thats ok for a starter bike and its a good choice to start with that bike you can always change to a rear magura as it has the mounts. Quote Link to comment Share on other sites More sharing options...
Little Yoshi Posted June 18, 2009 Report Share Posted June 18, 2009 11.45kg.I have never tried them disk brakes but i would change to HS33's. Cos when your learning and you slip of somthing you could damage the rotor. Quote Link to comment Share on other sites More sharing options...
AaronR504 Posted June 18, 2009 Report Share Posted June 18, 2009 some guy down my road has just bought one and its a realy easy bike to get onto the back wheel wheel with and to learn the basics... from what i can make out aswell it is also a very strong frame as he is a pretty big guy and has bailed out at a few times from pretty high ledges and its been completely fine, not even a scratch hope it helps Quote Link to comment Share on other sites More sharing options...
simlesuperlol Posted June 18, 2009 Author Report Share Posted June 18, 2009 do you know if it's a good frame (the pro) to uprgade later or I should totaly change when I get better? Quote Link to comment Share on other sites More sharing options...
Little Yoshi Posted June 18, 2009 Report Share Posted June 18, 2009 do you know if it's a good frame (the pro) to uprgade later or I should totaly change when I get better?I have a t-pro and i belive the frams are pretty much the same.Yeah the frame is a good solid frame that you can upgrade parts on. Quote Link to comment Share on other sites More sharing options...
bigamac Posted June 18, 2009 Report Share Posted June 18, 2009 11.45kg.I have never tried them disk brakes but i would change to HS33's. Cos when your learning and you slip of somthing you could damage the rotor.Ignore him.Yes you may ben the rotor, but nothing better than an adjustable spanner fixes that.Onza disk brakes are amazing so you don't need a hs33.I vote get the bike. Quote Link to comment Share on other sites More sharing options...
Little Yoshi Posted June 18, 2009 Report Share Posted June 18, 2009 Ignore him.Yes you may ben the rotor, but nothing better than an adjustable spanner fixes that.Onza disk brakes are amazing so you don't need a hs33.I vote get the bike.Never knew about the trick with the spanner, Cheers! Quote Link to comment Share on other sites More sharing options...
haderz Posted June 20, 2009 Report Share Posted June 20, 2009 chainstay length of 375 seems a bit much =/? Quote Link to comment Share on other sites More sharing options...
simlesuperlol Posted June 20, 2009 Author Report Share Posted June 20, 2009 chainstay length of 375 seems a bit much =/?What does it changes? Quote Link to comment Share on other sites More sharing options...
alex-trials-boy Posted June 23, 2009 Report Share Posted June 23, 2009 Hey mate its a good bike and weighs 11.45kg look at the bottom on the page. hope this helps. http://www.tartybikes.co.uk/product.php?pr...;category_id=10 Quote Link to comment Share on other sites More sharing options...
