Hope Mono Problem
bikeperson45
Right after I had another spoke fitted went out my house for a quick 10 minute spin. Rode for about 15 minutes then all of a sudden brake went mush. I don't understand how it happened, one second they were working perfectly, then the next second, they weren't. It's just a bloody joke now.
When I pull the lever, at first doesn't do anything, then pull it a bit futher and completly locks the wheel, then takes a while for pads to move away from the rotor again. What can I do to fix this? Please help
Thanks
Getting it serviced, with new caliper pistons and seals is the only sure way to fix it. You can send it off to Hope and they will do all this for a very reasonable price, about £40 I think.
If you can't afford that, giving it a clean may help. Take the pads out and clean around the caliper pistons with an old toothbrush and some gt85. Once it is all clean you can try working the pistons, pull the lever to pump the pistons out(make sure they don't come out more than 5 or 6 mm or you could pop them out of the caliper bore completely). When you pull the lever both pistons should come out evenly, if this is not the case then you need to work the slow piston. Carefully push the pistons back with flat bladed screwdriver or small spanner. Now hold the good piston in place with said tool and pull the lever until the sticky piston moves. Once it is out 5mm or so, make sure it is all clean, give it a spray of gt85 if needed then push it back into the caliper. Keep pumping it out and pushing it back until it frees up, than check if both pistons move equally again. Once your done make sure you push both pistons back and wipe off any excess degreaser before refitting the pads, then refit the brake and give it a try.
If your lucky that might cure the problem, but 90% of the time you get sticky pistons it is due to worn caliper seals and the only thing you can do is replace them all...
You can pump them all the way out. And then its easyer to clean. I used some 1000 grade wet and dry to take any bur's off the pistons. When replacing them, give them a good squirt of Gt85 and re blead.
Whatever you do, don't do that! Sanding brake pistons?!?
Sorry, it was one of those obvious things that you need someone else to notice :$
The previous owner of the bike had put ziptie around it so it wouldn't get in the way, and after a footham tailwhip attempt, it wrapped round more so squeezed it together.
Thanks for replys, I'll bear them in mind when something does go wrong
