RyanMcVicker Posted June 16, 2009 Report Share Posted June 16, 2009 What forks can I use with my Hope Trials disc brake? I have a 180mm rotor. I want to get a new lighter fork for my new frame and I noticed that all forks these days have non-standard tabs +20, +30 etc... I have no idea what adapters I'll need or whatnot to still be able to use my current disc brake. Please help me.. Cheers and thanksRyan Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted June 16, 2009 Report Share Posted June 16, 2009 Which caliper # do you have currently? Or which fork? Quote Link to comment Share on other sites More sharing options...
RyanMcVicker Posted June 16, 2009 Author Report Share Posted June 16, 2009 I don't know what caliper number. I have the Echo hifi fork with CNC crown area. Caliper is hope trials brake with 180 rotor size. No adapters. Quote Link to comment Share on other sites More sharing options...
N.Wood Posted June 16, 2009 Report Share Posted June 16, 2009 Caliper number is machined onto the caliper. Think its either 3 or 5 for 180mm. From what I can remember Hifis were ISO, so to use your caliper on some +20 forks you'd need a 200mm rotor. I'm sure Adam can confirm any parts I ot right and add in anything I forgot Quote Link to comment Share on other sites More sharing options...
RyanMcVicker Posted June 17, 2009 Author Report Share Posted June 17, 2009 what if i don't want a different rotor... i already have what i like Quote Link to comment Share on other sites More sharing options...
N.Wood Posted June 17, 2009 Report Share Posted June 17, 2009 Then you'll just have to get forks with an ISO mount, or if you can only find +20 forks, change your caliper for a 160mm one and you can use a 180mm rotor. Quote Link to comment Share on other sites More sharing options...
RyanMcVicker Posted June 17, 2009 Author Report Share Posted June 17, 2009 why are bikes so difficult. I just bought my hope trials last winter. Not buying a different one just because my fork. But the new frame i get will be based around a fork with 400mm/35 rake vs. mine which is 45 rake... GRRRRRRRRRRRRRRRRRRRR Quote Link to comment Share on other sites More sharing options...
N.Wood Posted June 17, 2009 Report Share Posted June 17, 2009 My frame is also based around a 400mm/35 rake fork, but I'm gangstar as f**k so use Trialtech forks instead. Needless to say my riding hasn't been affected by the 10mm difference. Quote Link to comment Share on other sites More sharing options...
r2wtrials Posted June 17, 2009 Report Share Posted June 17, 2009 Here is the front of my Echo Pure... Hi-fi forks and tryall disc. The Hope caliper is a number 3.Unfortunately the Tryall disc is actually 183mm so it had to have a shave on my bench grinder Quote Link to comment Share on other sites More sharing options...
