Onza Man 88 Posted June 14, 2009 Report Share Posted June 14, 2009 (edited) Hi everyoneRight i got a new back wheel then i needed snail cam so i got them then need to thread and make a hole for snail cam bolts did thati tightened up my wheel as tight as i can and my back wheel is still slipping and i really started to get annoyed Ive spend about£170 on the back and its its still slipping and loose chain I'm using Ecko snail cams because there the only ones that fit my Echo hub and rim so can any 1 help because its getting to the point were i want to sell me trials bike i don't but its annoying me that much and Ive been doing it for about a month please help any adviseThanks Kieran. Edited June 14, 2009 by Onza Man 88 Quote Link to comment Share on other sites More sharing options...
LukasMcNeal Posted June 14, 2009 Report Share Posted June 14, 2009 Hi everyoneRight i got a new back wheel then i needed snail cam so i got them then need to thread and make a hole for snail cam bolts did thati tightened up my wheel as tight as i can and my back wheel is still slipping and i really started to get annoyed Ive spend about£170 on the back and its its still slipping and loose chain I'm using Ecko snail cams because there the only ones that fit my Echo hub and rim so can any 1 help because its getting to the point were i want to sell me trials bike i don't but its annoying me that much and Ive been doing it for about a month please help any adviseThanks Kieran.Use the cams to tension the chain? Quote Link to comment Share on other sites More sharing options...
sstein Posted June 15, 2009 Report Share Posted June 15, 2009 (edited) Hi everyoneRight I got a new back wheel then I needed snail cams so I got them, then I needed to thread and make a hole for snail cam bolts, so I did that.I tightened up my wheel as tight as I could and my back wheel is still slipping. I am really starting to get annoyed I've spent about £170 on the back and its its still slipping and the chain keeps coming loose. I'm using Echo snail cams because they are the only ones that fit my Echo hub and rim so can any one help because its getting to the point were I want to sell my trials bike. I don't want to but it's annoying me that much and Ive been doing it for about a month please help any advise.Thanks Kieran.That is how you should have written that. Please make your posts easier to understand. Edited June 15, 2009 by sstein Quote Link to comment Share on other sites More sharing options...
eskimo Posted June 15, 2009 Report Share Posted June 15, 2009 If there's room for chain tugs try them. You might have some more luck. If not slack chain is what your have to deal with. But snail cams if set up right should provide okay/rideable/safe tension. Quote Link to comment Share on other sites More sharing options...
MikeCottTrials Posted June 15, 2009 Report Share Posted June 15, 2009 Chain tugs make snail cams redundant Quote Link to comment Share on other sites More sharing options...
Rob. Posted June 15, 2009 Report Share Posted June 15, 2009 You will probably need chain tugs instead of snail cams , I believe you are riding an onza T-mag , I dont think them frames have anywhere for the snail cam bolts to go in , so thats why your wheel is moving/slipping, somebody correct me if I am wrong.Rob. Quote Link to comment Share on other sites More sharing options...
LukasMcNeal Posted June 15, 2009 Report Share Posted June 15, 2009 You will probably need chain tugs instead of snail cams , I believe you are riding an onza T-mag , I dont think them frames have anywhere for the snail cam bolts to go in , so thats why your wheel is moving/slipping, somebody correct me if I am wrong.Rob.I think they might have cam bolt holes because my T-Pro has cam bolt holes. Quote Link to comment Share on other sites More sharing options...
