AdamR28 Posted April 1, 2010 Report Share Posted April 1, 2010 Is it the longer the spring the louder it is..? Kinda. It can make the hub skip though if you feck it up. Stretching the spring isn't worth doing. Quote Link to comment Share on other sites More sharing options...
Mikey-uk Posted April 1, 2010 Report Share Posted April 1, 2010 (edited) Trying to knock the bearing out atm... It seems im on the path to knocking the bearings apart rather than out, they wont budge and im really worries that i'm gunna knock the middle part out instead of the outer. Anyone know how I could avoid this? Maybe find a working video out to knock it out with the drive shaft locked in? Edit - Nvm, hit it harder, worked. Edit #2 - Do I NEED to lube it? Edited April 1, 2010 by Mikey-uk Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted April 1, 2010 Report Share Posted April 1, 2010 Trying to knock the bearing out atm... It seems im on the path to knocking the bearings apart rather than out, they wont budge and im really worries that i'm gunna knock the middle part out instead of the outer. Edit - Nvm, hit it harder, worked. Quote Link to comment Share on other sites More sharing options...
Mikey-uk Posted April 1, 2010 Report Share Posted April 1, 2010 (edited) dont worry adam its fine some people have been telling me its perfectly fine to run a king dry... is it? Edit - Just tried it dry and I can feel resistance just spinning it so ima go get some lube from cyclezone Cheers for the video Edited April 1, 2010 by Mikey-uk Quote Link to comment Share on other sites More sharing options...
Mr Motivator Posted April 1, 2010 Author Report Share Posted April 1, 2010 Make sure you lube the helix spline on the drive shell; that's what makes the hub work. Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted April 1, 2010 Report Share Posted April 1, 2010 Edit - Just tried it dry and I can feel resistance just spinning it so ima go get some lube from cyclezone There will be less resistance from no lube, that resistance is probably from the bearing you just almost murdered hehe Quote Link to comment Share on other sites More sharing options...
Mr Motivator Posted April 1, 2010 Author Report Share Posted April 1, 2010 Most likely yes. You need to be very careful pulling a bodge like this. Kings are made to such high tollerances (more than they need to be really) Like Adam has said, if you really value your king and don't want to risk anything then just leave it alone or send it to Adam for his super service. I only did this because my king is getting old, I don't ride much any more and a lot of people ask if they can make it louder and most don't seem to care if it wears out thier Hub faster. Anyway, have fun it'll be fine. Quote Link to comment Share on other sites More sharing options...
MMMM-JASON Posted April 1, 2010 Report Share Posted April 1, 2010 I only did this because my king is getting old, I don't ride much any more and a lot of people ask if they can make it louder and most don't seem to care if it wears out thier Hub faster. Anyway, have fun it'll be fine. If i was to spend that much money on a hub i would want it to work ever. People who dont care clearly have to much money and sholud give me some and have mostly likely been droped as a child. Quote Link to comment Share on other sites More sharing options...
josh barker Posted April 7, 2010 Report Share Posted April 7, 2010 dont do this just a good way to f**k up the bearing with the punch, dont bother Quote Link to comment Share on other sites More sharing options...
Borat Posted April 7, 2010 Report Share Posted April 7, 2010 dont do this just a good way to f**k up the bearing with the punch, dont bother Shut up! It's fine, just hit it lightly and square! Quote Link to comment Share on other sites More sharing options...
Luke_zoo Posted April 7, 2010 Report Share Posted April 7, 2010 Was going to do this with mine, but doesnt seem worth it? Quote Link to comment Share on other sites More sharing options...
josh barker Posted April 7, 2010 Report Share Posted April 7, 2010 (edited) Shut up! It's fine, just hit it lightly and square! tried it, doesnt budge 1 bit but i have re-assembeled the bearing and it seems ok i would rather spend 150quid on the chris king toool to be honest instead of boging Edited April 7, 2010 by josh barker Quote Link to comment Share on other sites More sharing options...
Borat Posted April 7, 2010 Report Share Posted April 7, 2010 tried it, doesnt budge 1 bit but i have re-assembeled the bearing and it seems ok i would rather spend 150quid on the chris king toool to be honest instead of boging No, you'd rather your Dad fork out 150 on you. Quote Link to comment Share on other sites More sharing options...
DannyBazz (: Posted April 7, 2010 Report Share Posted April 7, 2010 No, you'd rather your Dad fork out 150 on you. I lol'd But in all fairness, I'd probably prefer to buy the tool too. If I had 150 lying about that is. Or even if I had a king. Quote Link to comment Share on other sites More sharing options...
josh barker Posted April 7, 2010 Report Share Posted April 7, 2010 No, you'd rather your Dad fork out 150 on you. paha, you dont understand it is my dads chris king hub, on his bike so you cant say note. Quote Link to comment Share on other sites More sharing options...
Mikey-uk Posted April 7, 2010 Report Share Posted April 7, 2010 Well I did this AGAIN at Chinner's house just 'cos I wanted a bigger penis (We all know that a louder king = bigger penis) and it sounds amazing. I stretched the spring a little and instantly it started to mis-shape so I left it. If I had £13 to buy a new spring then I'd see how far I could stretch this current one but alas I dont D: Anyways, amazing guide It helped me and i'm sure it helped others. Quote Link to comment Share on other sites More sharing options...
Revelation Posted April 7, 2010 Report Share Posted April 7, 2010 I see it can make the king louder, but how does it make it skip less? Quote Link to comment Share on other sites More sharing options...
Mikey-uk Posted April 7, 2010 Report Share Posted April 7, 2010 Kings come packed with a shit tonne of grease which cloggs it up, also over time you managed to acumilate a lot of dirt and other shit in the drive rings. Quote Link to comment Share on other sites More sharing options...
davey1991 Posted April 9, 2010 Report Share Posted April 9, 2010 I see it can make the king louder, but how does it make it skip less? Kings come packed with a shit tonne of grease which cloggs it up, also over time you managed to acumilate a lot of dirt and other shit in the drive rings. As well as this, stretching the spring forces the pawls into the hub with more force that if it was left un-stretched. This can lead to more wear from greater friction. Quote Link to comment Share on other sites More sharing options...
N.Wood Posted April 9, 2010 Report Share Posted April 9, 2010 As well as this, stretching the spring forces the pawls into the hub with more force that if it was left un-stretched. This can lead to more wear from greater friction. Kings don't have pawls 1 Quote Link to comment Share on other sites More sharing options...
craigjames Posted April 9, 2010 Report Share Posted April 9, 2010 They don't have pawls and use King Lube which isn't grease. Some are loud and some are quiet, the one on my stock is a hell of a lot louder than the one on my 24" both were bedded in on XC bikes too. Quote Link to comment Share on other sites More sharing options...
