Ayuli Posted June 11, 2009 Report Share Posted June 11, 2009 Good morning matesjust bought my first (used) bikei need to swap the sides of the brakes (i.e. rear brake at the right hand side)guess there will be no prob with the rear magi but what about the front (hope mono trials Tryall edition) ?can i run it safely with the red bath cover facing down ?!tnx Asaf Quote Link to comment Share on other sites More sharing options...
bigamac Posted June 11, 2009 Report Share Posted June 11, 2009 Why do you need to swap it? seems a silly idea. Quote Link to comment Share on other sites More sharing options...
315r Posted June 11, 2009 Report Share Posted June 11, 2009 Because this combination only work in UK.... Is no good idea to put hope upside down... Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted June 11, 2009 Report Share Posted June 11, 2009 Don't turn it upside down, by the way I ride with the brakes this way round too, it's a pain in the arse with hope brakes. I have got hopes front and back now so I just swapped hoses/calipers/levers around till it was right for me. Before that I used a Formula "The one" front disk which has a flip flop lever and has the added bonus of being way light.Click meOther than that try and find someone with a rear hope that wants to swap levers (Good luck with that I tried this for ages!!!)I've still got the Formula brake so if you get really stuck we could swap.Matt Quote Link to comment Share on other sites More sharing options...
Revolver Posted June 11, 2009 Report Share Posted June 11, 2009 Why don't you leave it like it is? There's nothing stopping you learning to use the brakes on the opposite sides. I've switched over a few times. Quote Link to comment Share on other sites More sharing options...
Ayuli Posted June 11, 2009 Author Report Share Posted June 11, 2009 Why don't you leave it like it is? There's nothing stopping you learning to use the brakes on the opposite sides. I've switched over a few times.been riding MTB for 13 that way (rear = right)i'm sure that i need to swap sides.will the hope malfunction if the bath will face down - any serious bike mechanic around here ?! Quote Link to comment Share on other sites More sharing options...
Mat Smith!! Posted June 11, 2009 Report Share Posted June 11, 2009 been riding MTB for 13 that way (rear = right)i'm sure that i need to swap sides.will the hope malfunction if the bath will face down - any serious bike mechanic around here ?!Air will get in the system if you run it upside down, I'm sure. Quote Link to comment Share on other sites More sharing options...
forteh Posted June 11, 2009 Report Share Posted June 11, 2009 Air will get in the system if you run it upside down, I'm sure.If youre lucky and manage to roll the diaphragm into a completely full resevior then you might get away with it, I doubt it would accomodate any pad wear as its meant to. Chances are it wll induct air, just get another hope lever Quote Link to comment Share on other sites More sharing options...
psycholist Posted June 11, 2009 Report Share Posted June 11, 2009 Atmospheric pressure should be enough to allow the lever to compensate for pad wear (It'll support a 10m water column, so a cm of DOT Fluid won't be a problem). The problem is that any air bubbles will tend to end up in the brake line though if you're lucky they might stick elsewhere in the reservoir. Problems like variable brake bite point and sponginess are almost certain to keep recurring though. Quote Link to comment Share on other sites More sharing options...
Muel Posted June 11, 2009 Report Share Posted June 11, 2009 You'd have to bucket bleed the hope to get it completely air tight, you can never get all the air out from under the diaphragm!I'm always really careful when putting the diapgragm back on, but I can never get it right. They're a shite design, I had a set of Shimano Deores on another bike and it was far easier and you could stand the bike upside down on the car without worry.I'd try and get someone to swap, or get an english rear brake and swap the levers, then sell the english rear brake with the left hand lever on in your country, and it will be the right side for a rear. Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted June 11, 2009 Report Share Posted June 11, 2009 You'd have to bucket bleed the hope to get it completely air tight, you can never get all the air out from under the diaphragm!I'm always really careful when putting the diapgragm back on, but I can never get it right. They're a shite design, I had a set of Shimano Deores on another bike and it was far easier and you could stand the bike upside down on the car without worry.I'd try and get someone to swap, or get an english rear brake and swap the levers, then sell the english rear brake with the left hand lever on in your country, and it will be the right side for a rear. Ha Ha, or move to spain! Matt Quote Link to comment Share on other sites More sharing options...
Ayuli Posted June 11, 2009 Author Report Share Posted June 11, 2009 Thank you all for the advice.....i think that i'll look for a used hope left lever or put there something else Quote Link to comment Share on other sites More sharing options...
trials ryan Posted June 11, 2009 Report Share Posted June 11, 2009 I run brakes the wrong way round, since day 1. Why not keep it that way? Only thing is mates call me forin. Quote Link to comment Share on other sites More sharing options...
