Marijn Posted June 10, 2009 Report Share Posted June 10, 2009 As the title it says..What do you think about the Onza Pro 2009 , as my first trialsbike?Description- Excellent value 20" wheel trials bike from Onza, ideal for beginner or fast learning riders.- High grade 6061-T6 aluminium frame with rear disc mount, integrated chain tensioners and head tube reinforcing gussets.- Tough Onza cromoly forks with 4-Bolt Magura brake mount and disc brake mount.- Powerful Onza cable disc brakes front and rear, a massive breakthrough at this price point, ensuring predictable and reliable braking in all conditions.- Onza Skim rims, 20" front and 19" rear.- Maxxis Creepy Crawler tyres, 20 x 2.0" front and 19 x 2.5" rear.- T-Pro crankset fitted with durable knurled bashring and 18T Tensile freewheel with 60 engagement points for maximum pedalling response.- Bash/ski-plate fitted as standard.- Onza cromo stem and 'flat' trials handlebar.- New Onza caged pedals.- 12T screw on sprocket on the rear hub, running 18-12 gear ratio.- Seatless design to reduce weight and increase stand over clearance.- Gloss grey frame with gloss black forks, both with Onza logos.- Weight: 11.45kg including pedals.Geometry (to be confirmed)Wheelbase: 1005mmChainstay Length: 375mmBB Rise: 55mm 1 Quote Link to comment Share on other sites More sharing options...
a.l.3.x.13@hotmail.com Posted June 10, 2009 Report Share Posted June 10, 2009 Hey the pro looks like quite a good starter bike, they have a good strong light ish frame and over all a good all-round bike, you might want to suggest looking at the Onza t-pro, maybe the t-mag up to you but yes it’s a good beginner bike. Quote Link to comment Share on other sites More sharing options...
JaMiE.oNzA Posted June 10, 2009 Report Share Posted June 10, 2009 hi mate, ive got one of these and i would strongly recommend it .ive only been riding a couple of months now and i have learnt quite alot on it . Quote Link to comment Share on other sites More sharing options...
adam 94 Posted June 10, 2009 Report Share Posted June 10, 2009 Bike looks good for you to start as its got magura and disc mounts. If i were you and i had the money id go for it Quote Link to comment Share on other sites More sharing options...
kona1991 Posted June 11, 2009 Report Share Posted June 11, 2009 If you have the money then go for it...However i wouldnt be to keen on running dual disc as a complete beginner, because there may be few risky bails Quote Link to comment Share on other sites More sharing options...
jack vickers Posted June 11, 2009 Report Share Posted June 11, 2009 i think it is a good bike to start off with i have a onza t-bird that is good but it looks awesome Quote Link to comment Share on other sites More sharing options...
craiggy1984 Posted June 12, 2009 Report Share Posted June 12, 2009 Yes mate,these bikes are definately a good starter bike,i rode for 4yrs about 9yrs ago then quit,i have just started again on a 2005 t-pro,pretty much the same frame as the later ones jus mines an anodized bronze sort of colour and i have no disc mounts,i used to ride stock,now im ridin the mod,and i find it very good on the back wheel,picking it all up again at a pretty fast pace,goin london riding tommoro....yay hope u get on ol and good luck with your riding buddy Quote Link to comment Share on other sites More sharing options...
Marijn Posted June 13, 2009 Author Report Share Posted June 13, 2009 Hi , thanks for all the reactions !Tartybikes' owner mailed me that my bike will arrive next Thursday , and I can't wait man !Marijn. Quote Link to comment Share on other sites More sharing options...
trials ryan Posted June 13, 2009 Report Share Posted June 13, 2009 If you have the money then go for it...However i wouldnt be to keen on running dual disc as a complete beginner, because there may be few risky bails Like sidehops = bent disc rotors. Quote Link to comment Share on other sites More sharing options...
Jack Chinnery Posted June 13, 2009 Report Share Posted June 13, 2009 As the title it says..What do you think about the Onza Pro 2009 , as my first trialsbike?Description- Excellent value 20" wheel trials bike from Onza, ideal for beginner or fast learning riders.- High grade 6061-T6 aluminium frame with rear disc mount, integrated chain tensioners and head tube reinforcing gussets.- Tough Onza cromoly forks with 4-Bolt Magura brake mount and disc brake mount.- Powerful Onza cable disc brakes front and rear, a massive breakthrough at this price point, ensuring predictable and reliable braking in all conditions.- Onza Skim rims, 20" front and 19" rear.- Maxxis Creepy Crawler tyres, 20 x 2.0" front and 19 x 2.5" rear.- T-Pro crankset fitted with durable knurled bashring and 18T Tensile freewheel with 60 engagement points for maximum pedalling response.- Bash/ski-plate fitted as standard.- Onza cromo stem and 'flat' trials handlebar.- New Onza caged pedals.- 12T screw on sprocket on the rear hub, running 18-12 gear ratio.- Seatless design to reduce weight and increase stand over clearance.- Gloss grey frame with gloss black forks, both with Onza logos.- Weight: 11.45kg including pedals.Geometry (to be confirmed)Wheelbase: 1005mmChainstay Length: 375mmBB Rise: 55mmHey mate, I really reccomend you having the bike. I adore onzas.Plus I am also reporting you for validation. That has to be the best first post I have ever seen. See you around. x Quote Link to comment Share on other sites More sharing options...
Marijn Posted June 13, 2009 Author Report Share Posted June 13, 2009 First of all , thanks Jack.And about bending the disc rotors ; I may buy a second hand Magura HS33 for 25 € , that's .. 21 £.So I think that problem is solved too.PS : Sorry for my bad English , I'm from Belgium...Marijn Quote Link to comment Share on other sites More sharing options...
Jack Chinnery Posted June 13, 2009 Report Share Posted June 13, 2009 First of all , thanks Jack.And about bending the disc rotors ; I may buy a second hand Magura HS33 for 25 € , that's .. 21 £.So I think that problem is solved too.PS : Sorry for my bad English , I'm from Belgium...MarijnTheres nothing wrong with your english mate, it's fine. Quote Link to comment Share on other sites More sharing options...
JMathieson Posted June 13, 2009 Report Share Posted June 13, 2009 The Onza pro is a fairly good starter bike in my opinion! They have a good all round geometry and the brakes are good and powerful as long as you maintain them and set them properly. But definitely get new levers for them as the standard ones are awful! Quote Link to comment Share on other sites More sharing options...
Jack Chinnery Posted June 13, 2009 Report Share Posted June 13, 2009 I see your validated now, See trials forum; I can be nice. Good luck in members. x Quote Link to comment Share on other sites More sharing options...
Marijn Posted June 17, 2009 Author Report Share Posted June 17, 2009 I've recieved it today and it rides great ! Quote Link to comment Share on other sites More sharing options...
simlesuperlol Posted June 19, 2009 Report Share Posted June 19, 2009 I've recieved it today and it rides great !Can you give feed back on this cause I'm planning on buying the same I just want to make sure you love it Quote Link to comment Share on other sites More sharing options...
Marijn Posted June 19, 2009 Author Report Share Posted June 19, 2009 I really like it , but it's my first trialsbike , so I'm still learning the basics...But too me , it feels nice and stable. Quote Link to comment Share on other sites More sharing options...
edede Posted June 24, 2009 Report Share Posted June 24, 2009 Hi, i'm planning to buy the same bike, as my first trials bike, so now after a couple days can u tell how the onza rides? Quote Link to comment Share on other sites More sharing options...
Marijn Posted June 24, 2009 Author Report Share Posted June 24, 2009 Hi, i'm planning to buy the same bike, as my first trials bike, so now after a couple days can u tell how the onza rides? After my first week of riding with it , it's feels really great en comfortable.I already learnt several things on it.If I was you , and I had the money , I would buy it. Quote Link to comment Share on other sites More sharing options...
Stuart941 Posted June 24, 2009 Report Share Posted June 24, 2009 Woo it's my first bike too, just got it the other day Quote Link to comment Share on other sites More sharing options...
jack vickers Posted June 25, 2009 Report Share Posted June 25, 2009 i think that it is a good bike and i think for the money you r best goin on ebay like i did and get a really good bike for thr same price Quote Link to comment Share on other sites More sharing options...
Pavel Posted June 17, 2017 Report Share Posted June 17, 2017 Hey guys, just bought this bike from a second hand. Any ideas where I could buy spare parts? Some minor stuff, such as the aluminium small U shape chain tensioner? Quote Link to comment Share on other sites More sharing options...
Dman Posted June 19, 2017 Report Share Posted June 19, 2017 Contact tartybikes. 1 Quote Link to comment Share on other sites More sharing options...
