zoo 06 Posted June 10, 2009 Report Share Posted June 10, 2009 All my mates have told me to make my king louder, but how do i do it. thanks rob Quote Link to comment Share on other sites More sharing options...
N.Wood Posted June 10, 2009 Report Share Posted June 10, 2009 Take it apart, clean it all out, put in some tri-flow light lube, put it back together. Quote Link to comment Share on other sites More sharing options...
zoo 06 Posted June 10, 2009 Author Report Share Posted June 10, 2009 N.Wood said: Take it apart, clean it all out, put in some tri-flow light lube, put it back together.some one said somthing about streching the springs Quote Link to comment Share on other sites More sharing options...
J.KYDD Posted June 10, 2009 Report Share Posted June 10, 2009 do NOOOT stretch the spirngs. the way kings work they are best in a well oiled lubricated environment so keep it that way.so what if its not realy loud, does it still work well?the longer term cost of not keeping it lubricated or stretching the springs meen things will wear out faster and C/King spares are SILLY expensive! Quote Link to comment Share on other sites More sharing options...
zoo 06 Posted June 10, 2009 Author Report Share Posted June 10, 2009 kyddie said: do NOOOT stretch the spirngs. the way kings work they are best in a well oiled lubricated environment so keep it that way.so what if its not realy loud, does it still work well?the longer term cost of not keeping it lubricated or stretching the springs meen things will wear out faster and C/King spares are SILLY expensive!thanks mate Quote Link to comment Share on other sites More sharing options...
SunshineDiver Posted June 10, 2009 Report Share Posted June 10, 2009 It is impossible to make your hub louder without damaging it or making it more likely to wear.Your hubs noise depends on things like how many pawls are used, how tight the spring is, how dry the inside of the hub is and how deep the engagement points are.If you have to make it louder tightning the spring around the pawls or cleaning out the lube will make the hub louder but will also make it wear quicker.NEVER cut(deepen) the engagement points though . Some dirt jumper came into the bike shop i work in a while back who had done this and it was unfixable. Not worth the risk.Best bet would be to just leave it as is if your happy with it though. Quote Link to comment Share on other sites More sharing options...
N.Wood Posted June 10, 2009 Report Share Posted June 10, 2009 SunshineDiver said: It is impossible to make your hub louder without damaging it or making it more likely to wear.Your hubs noise depends on things like how many pawls are used, how tight the spring is, how dry the inside of the hub is and how deep the engagement points are.If you have to make it louder tightning the spring around the pawls or cleaning out the lube will make the hub louder but will also make it wear quicker.NEVER cut(deepen) the engagement points though . Some dirt jumper came into the bike shop i work in a while back who had done this and it was unfixable. Not worth the risk.Best bet would be to just leave it as is if your happy with it though.Whilst I agree, I can't take your advice seriously if you think Kings have pawls and numerous springs. Quote Link to comment Share on other sites More sharing options...
J.KYDD Posted June 10, 2009 Report Share Posted June 10, 2009 N.Wood said: Whilst I agree, I can't take your advice seriously if you think Kings have pawls and numerous springs. amen! Quote Link to comment Share on other sites More sharing options...
max-t Posted June 10, 2009 Report Share Posted June 10, 2009 Hehe. Thread makes me laugh. Stretch it lad, it will be fine. Quote Link to comment Share on other sites More sharing options...
Mat Smith!! Posted June 10, 2009 Report Share Posted June 10, 2009 kyddie said: do NOOOT stretch the spirngs. the way kings work they are best in a well oiled lubricated environment so keep it that way.so what if its not realy loud, does it still work well?the longer term cost of not keeping it lubricated or stretching the springs meen things will wear out faster and C/King spares are SILLY expensive!Spring.If it goes wrong it's really not that bad. Quote Link to comment Share on other sites More sharing options...
pogo Posted June 10, 2009 Report Share Posted June 10, 2009 Don't just don't. If it works leave it. Quote Link to comment Share on other sites More sharing options...
Skoze Posted June 10, 2009 Report Share Posted June 10, 2009 Mat Smith!! said: Spring.If it goes wrong it's really not that bad.What, when you've raped the drive/ driven rings? I wouldn't bother. Clean it out and whack some thin oil in there and it'll be louder and work a bit better, my hub's *probably* the quietest king i've heard, it's been cleaned out and had the lube changed etc but i love it, silly loud hubs do start to get annoying.If (like mine) it's working perfectly and doesn't skip, just leave it be - how does a loud hub help? (awaits "gi' us confidents mayte") Quote Link to comment Share on other sites More sharing options...
Mat Smith!! Posted June 10, 2009 Report Share Posted June 10, 2009 Skoze said: What, when you've raped the drive/ driven rings? I wouldn't bother. Clean it out and whack some thin oil in there and it'll be louder and work a bit better, my hub's *probably* the quietest king i've heard, it's been cleaned out and had the lube changed etc but i love it, silly loud hubs do start to get annoying.If (like mine) it's working perfectly and doesn't skip, just leave it be - how does a loud hub help? (awaits "gi' us confidents mayte")Well I've stretched both the springs on the 2 Kings I've had and they've never skipped or had any problems etc.mehhhhhh.. Quote Link to comment Share on other sites More sharing options...
SunshineDiver Posted June 10, 2009 Report Share Posted June 10, 2009 N.Wood said: Whilst I agree, I can't take your advice seriously if you think Kings have pawls and numerous springs.Soz man actually never worked on a chris king and jumped to a conclusion .Always thought they used a system like tht. Worth a read up on my part hahaSoz Quote Link to comment Share on other sites More sharing options...
thewoomaster Posted June 10, 2009 Report Share Posted June 10, 2009 (edited) The best way is to send it to Tarty for a service, when i got mine back it sound's 3 times louder Edited June 10, 2009 by thewoomaster Quote Link to comment Share on other sites More sharing options...
hdmackay Posted June 10, 2009 Report Share Posted June 10, 2009 Making a Chris King... even louder!?!? Quote Link to comment Share on other sites More sharing options...
MikeCottTrials Posted June 10, 2009 Report Share Posted June 10, 2009 thewoomaster said: The best way is to send it to Tarty for a service, when i got mine back it sound's 3 times louder who'd you get your inspired from? Quote Link to comment Share on other sites More sharing options...
thewoomaster Posted June 10, 2009 Report Share Posted June 10, 2009 Danny mac, was one of his free one's for riding for Inspired i guess if you want you can ask Dave M or his m8 kenny or him Quote Link to comment Share on other sites More sharing options...
Nick Manning Posted June 10, 2009 Report Share Posted June 10, 2009 Grant Hudley's king his super loud, the loudest one i've ever heard, so best bet would be to pm him. he told me he stretched the spring, but prob best to pm him for full details. Quote Link to comment Share on other sites More sharing options...
Mat Smith!! Posted June 10, 2009 Report Share Posted June 10, 2009 thewoomaster said: Danny mac, was one of his free one's for riding for Inspired i guess if you want you can ask Dave M or his m8 kenny or him So you bought a frame off Danny Mac which was one of his spairs? .Lets not start this again LOL. Quote Link to comment Share on other sites More sharing options...
Dave Anscombe Posted June 10, 2009 Report Share Posted June 10, 2009 (edited) Nick Manning said: Grant Hudley's king his super loud, the loudest one i've ever heard, so best bet would be to pm him. he told me he stretched the spring, but prob best to pm him for full details.His king gives me a head ache..........its also the loudest ive ever heard.and it never skips.....Its like no nother hub ive ever heardHe just stretched the spring Edited June 10, 2009 by Dave Anscombe Quote Link to comment Share on other sites More sharing options...
thewoomaster Posted June 10, 2009 Report Share Posted June 10, 2009 Yup and his prob got loads more now , was spanky new so i dont really care but yes lets not start it again. Quote Link to comment Share on other sites More sharing options...
zoo 06 Posted June 11, 2009 Author Report Share Posted June 11, 2009 whats the worst that can go wrong with it. Quote Link to comment Share on other sites More sharing options...
Skoze Posted June 11, 2009 Report Share Posted June 11, 2009 Rather a lot, actually. Quote Link to comment Share on other sites More sharing options...
